Clip-On Aero Bars for Stem
mrtkcmz
by mrtkcmz
Hi,
I have Zipp SL 70 Aero handle bar and I don't want to change it. for the next year there are few TT races and I want to use the same bike and same setup. But the problem is my handle bar is not accepting any clip-on aero bars because of tight tolerances (only 1 cm each side) . So are there any options for "stem" based clip-on aero bars? or do I need to make a custom one?
thanks
Lelandjt
by Lelandjt
If you can still find the Profile Hammer stem and Lightning Stryke aero bar it's exactly what you're looking for. Unfortunately they've been out of production for many years. I love mine. 2 bolts and 1 minute to mount or unmount the aero bar and it weighs less than a pound.
jeanjacques
by jeanjacques
Hello,
Not exactly what you looking for but a good solution to change from road to TT:
Haero Carbon, H.155 MTT SL (from 185g):
https://www.haero-carbon.com/fr/boutiqu ... 55-limited
H.380 TR SL (from 240g):
https://www.haero-carbon.com/en/shop/ha ... h380-tr-sl
jekyll man
by jekyll man
Deda Clip-one.
The main problem you'll have with many tribars is mounting the armrests somehow if they don't mount on the extensions.
Personally i'd just use some pipe lagging over the top of your barwhere your forearm will rest.
Official cafe stop tester
mrtkcmz
by mrtkcmz
Lelandjt wrote:If you can still find the Profile Hammer stem and Lightning Stryke aero bar it's exactly what you're looking for. Unfortunately they've been out of production for many years. I love mine. 2 bolts and 1 minute to mount or unmount the aero bar and it weighs less than a pound.
This is what I exactly want. but no chance. can't find it anywhere
mrtkcmz
by mrtkcmz
jekyll man wrote:Deda Clip-one.
sorry but this one clip-on to handlebar. not stem. not enough space on zipp sl 70 aero
rkan
by rkan
There is a 100mm stem on eBay at the moment at least. I'm fairly certain you will be able to find the aero bar come next summer at least...
cyclenutnz
by cyclenutnz
Jtek made a stem faceplate aerobar too, couldn't find any in a quick ebay search though.
http://www.speedtheory.co.nz
http://www.velogicfit.com - 3D Motion Capture and Frame Finder Software
addictR1
by addictR1
hi OP.. i have the same Zipp SL 70 aero bars. there's not much space available for aero clip on. you could use something like this.
https://goo.gl/U4i9QZ
Origin8 Mini Clip-On Tri Bars, 25.4 - 31.8
granted the bar is pretty short.. but perhaps can be replaced by other bars from other brands or use PVC pipe to reduce weight. i've thought about it but never went through with it. don't do enough tri to do get this for my TMR02
good luck
mrtkcmz
by mrtkcmz
addictR1 wrote:hi OP.. i have the same Zipp SL 70 aero bars. there's not much space available for aero clip on. you could use something like this.
good luck
I saw it before. +1 have you ever try it on SL 70 Aero? can you fit the clamps?
jekyll man
by jekyll man
I know it doesn't fasten on the stem, but the bar clamp is very narrow compared to most bolt on tribars, which is why i suggested it.
Also you dont say what stem you are using. Can you change it for something with a smaller face plate?
mrtkcmz
by mrtkcmz
it is a stock "Giant OverDrive Stem for Propel" not too much options for 1 1/4 stems with small face plate :(
Ltyarbro42
by Ltyarbro42
jeanjacques wrote:Hello,
Holy shit, that's hideous and I love it.
ddsg
by ddsg
The Selcof set from Planet-X is a nicer option imo. A bit heavy though.
https://www.planetx.co.uk/i/q/HBSEULTTBKIT/selcof-ultra-carbon-aero-road-triathlon-tribar-extension-kit
https://www.planetx.co.uk/i/q/HBSEULTMAX/selcof-ultra-carbon-aero-road-triathlon-handlebar
mrtkcmz
by mrtkcmz
new handle bars :(
