Ok to use carbon rails?
addictR1
by addictR1
Om my TMR02, im currently using Romin Evo saddle with Ti rail. Would like to use the Romin Evo Pro with carbon rail but not sure if ok to use with this type of clamp. It's bolted down from the top, so it's a bit hard to run a ratchet through the cut out to torque down.
Thoughts?
TonyM
by TonyM
I use a saddle with carbon rails for 3 seasons now without any problems.
https://www.selleitalia.com/en/saddles/ ... -carbonio/
Edit: the rails are "Carbo-Keramic"
Chris3g
by Chris3g
Carbon saddle rails are solid, there is not really a risk of cracking them due to over tightening as there is with Seatposts or handlebars, which are hollow. So yes, it’s fine.
slowK
by slowK
I have the same Selle San Marco Aspide saddle with oval carbon rails on both my bikes. One seat post has the proper cradle/clamp for ovalised carbon rails, the other just has the standard clamp for round rails. No issues with either. (But I'm 58kg.)
addictR1
by addictR1
Thanks guys.. I recall on he Romin Evo pro they suggested not to use oval type of seat clamp. So hopefully should be ok. My ass is designed in with the Romin Evo pro so prefer to stick with that saddle.
deano87
by deano87
shouldnt have any problems at all.
Theyre very solid
The Journey is more important than the Destination!
reedplayer
by reedplayer
no problems at all, for years! (saddle weighs 90 gr.) :wink:
RussellS
by RussellS
I have a Fizik saddle with carbon rails. Carbon Control Tech seatpost with aluminum clamp on top. Its worked fine for 7 years now.
addictR1
by addictR1
reedplayer wrote:no problems at all, for years! (saddle weighs 90 gr.) :wink:
Omg... 90g saddle only? Too bad DASH doesn't have those demo programs anymore...
Butcher
by Butcher
I had a C64 Selle Italia saddle that I broke the saddle but the rails were fine. If the rails were hollow [Which I believe they are not] then they could crush and break. Since they are solid, I really do not think you could crush them.
