Favero Assioma PowerMeter Pedals
does anyone know a release date of the rumored SPD compatible favero pedals? how do you think they will compare to garmin rally?
I hope there will be news in a few weeks. I don't know how long I can wait to buy a powermeter.gravelginger77 wrote:does anyone know a release date of the rumored SPD compatible favero pedals? how do you think they will compare to garmin rally?
Enviado desde mi MI 8 mediante Tapatalk
Will these just be the exisiting spindles in SPD-SL bodies or a whole new product?
Will they refresh the current Look-based pedals or are there no changes to the electronics?
There is no news of a refresh to the Look-based model.ccparkhill wrote:Will they refresh the current Look-based pedals or are there no changes to the electronics?
The new version of Assioma suitable for Shimano SPD-SL is not ready for sale yet. So while Favero completes the product, manufactures and distributes it, I think it's difficult that we can buy it before September. It's a personal opinion.juanj wrote:I hope there will be news in a few weeks. I don't know how long I can wait to buy a powermeter.gravelginger77 wrote:does anyone know a release date of the rumored SPD compatible favero pedals? how do you think they will compare to garmin rally?
Turns out there's a filed on Edge 530 where when it has detected a power meter with Cycling Dynamic, it enables that field. But somtimes its not sticky. I just enabled it and all good since.SixThirteen wrote: ↑Sun Mar 14, 2021 12:03 pmGot the Assioma Duo. First up they read about 1% higher than my PowerTap hub.
Second I'm having issues with Torque Effect. On outdoor rides generally it records. On indoor rides it generally doesn't. Curiously on the TE section of Cycling Dynamics the field flick on and off every few seconds.
Got a ticket open with support.
Six13
I've no idea what to do with all the extra data though
Scott Foil RC10 Ultegra 12 speed / Creston 50 - 7.9Kg
Actually nothing (imo)SixThirteen wrote: ↑Sun May 09, 2021 9:09 amTurns out there's a filed on Edge 530 where when it has detected a power meter with Cycling Dynamic, it enables that field. But somtimes its not sticky. I just enabled it and all good since.SixThirteen wrote: ↑Sun Mar 14, 2021 12:03 pmGot the Assioma Duo. First up they read about 1% higher than my PowerTap hub.
Six13
How exactly do you think the powertap hub can guess your chain transmission losses? That's assuming that it even tries to calculate "watts reaching the crankset" instead of "watts reaching the freehub driver".SixThirteen wrote: ↑Sun Mar 14, 2021 12:03 pmGot the Assioma Duo. First up they read about 1% higher than my PowerTap hub.
(OT: seriously, why did nobody ever do an "invisible" powermeter in the shape of an aftermarket freehub body back before pedals or "comes with the crankset anyways" became the norm? There's so much unused space in there!)
Sounds like an issue with the headset getting confused between Bluetooth and ANT+ (no cycling dynamics in Bluetooth). I guess your trainer is Bluetooth? Or it's an issue of the pedals getting confused serving both Bluetooth and ANT+ at once (when they are linked up to e.g. Zwift or GoldenC via BLE). Most of that stuff is running on a software component from the chip designer and those basics are rock-solid, but from what I remember from my little adventure in ANT+ programming I suspect that there might be a way to occasionallyskip the cycling dynamics part when getting distracted with Bluetooth.Second I'm having issues with Torque Effect. On outdoor rides generally it records. On indoor rides it generally doesn't. Curiously on the TE section of Cycling Dynamics the field flick on and off every few seconds.
Is this a joke? There's not that much room in a freehub. Most of it has to accommodate a 15-20mm wide hub axle. There's way too many freehub standards to accommodate, so you may as well make it all easier on yourself by making use of the entire hub. Voila, you've just invented the PowerTap rear hub.
You can hack them together with Xpedo bodies now. It's not clear whether a Shimano spindle that was pictured would be compatible with PD-M540 but people are hopeful. Release date unclear. Apparently Favero are made in Italy and took a real hammering during the pandemic so maybe things have been delayed.
That market could do with some options. Apparently SRM are hard to get hold of and Garmin Rally seem to have sold existing stock pretty fast. Given that those two options are at the same pricepoint if Favero undercut them I'm sure they would have some good sales numbers on their hands.
