fastbike21
by fastbike21 on Sat Mar 13, 2021 8:01 am
fastbike21 wrote: ↑Thu Mar 11, 2021 12:04 pm
jlok wrote: ↑Tue Mar 09, 2021 12:34 pm
fastbike21 wrote: ↑Tue Mar 09, 2021 12:32 pm
My DUO is reporting a significant imbalance since upgrading to the new firmware. I have scrolled all my previous rides and L/R power was max 1% apart. Since the upgrade it seems now fixed @ 54/46 or 53/47 . It seems something weird has happened...
Has anyone noticed the same behaviour?
Have you done some basic testing like single-leg pedaling to see if it would report 100-0?
Will do it!
I can't think of anything else as my setup hasn't changed. Can difference in worn out cleats be involved in this?
Ok I tested the l/r
R unclipped and spinning only with L pedal Wahoo shows 100/0
L unclipped and spinning only with R pedal shows from 43/57 to 40/60. This isn't normal behaviour, is it?
TobinHatesYou
by TobinHatesYou on Sat Mar 13, 2021 8:08 am
fastbike21 wrote: ↑Sat Mar 13, 2021 8:01 am
Ok I tested the l/r
Definitely not. It should be 100%-0% and 0%-100%
SixThirteen
by SixThirteen on Sun Mar 14, 2021 12:03 pm
Got the Assioma Duo. First up they read about 1% higher than my PowerTap hub.
Second I'm having issues with Torque Effect. On outdoor rides generally it records. On indoor rides it generally doesn't. Curiously on the TE section of Cycling Dynamics the field flick on and off every few seconds.
Got a ticket open with support.
Six13
Scott Foil RC10 Ultegra 12 speed / Creston 50 - 7.9Kg
Lina
by Lina on Sun Mar 14, 2021 12:13 pm
SixThirteen wrote: ↑Sun Mar 14, 2021 12:03 pm
Six13
Reading 1% higher than your powertap hub sounds about right, drivetrains aren't lossless and the hub is measuring from later on than the pedals.
handler
by handler on Sun Mar 14, 2021 2:15 pm
Bought a new pair Duos and they have been showing -5% compared to my Kickr Core which is also new. Both have been calibrated and I have even calibrated the Favero with a calibrated 12kg weight but they still substantially lower power. Tested with pedal spacers and without with no improvement. Any ideas?
TribesMan
by TribesMan on Sun Mar 14, 2021 3:25 pm
Problem is not in the pedals, you can be sure about that
Kickr Core does not "measure" the power, it only estimates it, and it seems the estimation is not very accurate.
patrikantonius
by patrikantonius on Sun Mar 14, 2021 4:40 pm
handler wrote: ↑Sun Mar 14, 2021 2:15 pm
you can scale up the assioma reading in the app if you want it to match your kickr
gurk700
by gurk700 on Sun Mar 14, 2021 7:36 pm
Haven't been an issue for me. I've always been 50-50 or 51-49 and it hasn't changed after firmware update.
mrlobber
by mrlobber on Mon Mar 15, 2021 10:33 am
TobinHatesYou wrote: ↑Sun Mar 14, 2021 7:16 pm
KICKR Cores are known to read high.
As always, there are exceptions, mine reads 20W low compared to 3 other powermeters from different brands.
milanv
by milanv on Wed Mar 17, 2021 8:15 am
TribesMan wrote: ↑Sun Mar 14, 2021 3:25 pm
Yes, correct, Kickr Core is not giving right numbers...
Lliones
by Lliones on Wed Apr 28, 2021 4:35 pm
Hi all Favero Assioma owners.
Anyone knows which the closest pedal to the Assioma is?
I bought a left side one only and looking for something to match it on the right side.
I've a look keo max 2 carbon pedals. Would these be close enough?
LOOK
Keo 2 Max Carbon
- Platform area: 500mm²
- Platform width: 60mm
- Q Factor: 53mm
- Stack height + cleats: 17.3mm (11 + 6.3mm)
