Campagnolo warranty question
Noctiluxx
by Noctiluxx
Hey guys,
I have my Campy Bora Ultra 50 clincher at the LBS as my rear wheel has too much play. I assumed the issue was the small 2.5mm hub screw was loose but after tightening, the issue persisted. I plan on calling Campy USA tomorrow to see if they honor warranty issues of products purchased from the UK. I purchased these wheels from Merlin Cycles September, 2016. Anyone in the US have similar experience? Thanks!
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2016 Specialized Allez DSW Sprint (Gold)
Hellgate
by Hellgate
Over the years I've found Campy to be very good when it comes to warrenty asks. My last one was a first generation, Record, Carbon crank. I had a nice, new Gen 2 a couple of weeks later.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Calnago
by Calnago
I think this is a pretty easy adjustment. That small screw is simply for locking down the “adjusting nut” once it’s been adjusted. But I find the adjusting nut itself is sometimes hard to get a good feel on just how “adjusted” the cone is to the bearings. What i do is remove that adjusting nut, then using a 17mm deep socket or something (I use one from a DT Swiss toolkit), put the socket over the axle and give the compression ring a little tap with a hammer to set it against the bearings. Then put the adjusting nut back on and fine tune it before locking it down finally with the small screw you referred to. If you have no idea what I’m talking about I’m sure you would once you started working on it and removing things on the non-drive side of the axle. They are super easy hubs to work on, and I pretty much always end up doing exactly this on my first service of a new Campy wheel. I don’t think it requires anything more than that, but surely if it’s in the shop they would have done this already, no? Although, You never know the level of competency at some of these shops especially when it comes to Campy.
bikerjulio
by bikerjulio
I've had a Campy wheel that needed adjusting out of the box.
It can even be done on the bike. The best place to feel for play.
Loosen the little lock screw and use a thin wrench on the adjusting nut. Tighten very gradually and feel for play on the wheel. With play gone and wheel spinning freely, tighten the little locknut.
There's sometimes a buggy.
One.
Noctiluxx
by Noctiluxx
Some really good info guys, thanks!
3Pio
by 3Pio
Both of my wheelsset (Shamal Ultra and Bora One 35) needed adjustment on the rear wheel. As i remember they are suppose to have small play which will be lost when u put them on the bike, so it's the best to check if there is play or not on the bike.
AS i remember i found soume youtube videos how to to do it and it's 5 min job...
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
Noctiluxx wrote:
Tue Oct 31, 2017 1:02 am
Hey guys,
Very old thread I know, but in case anyone trips over this question - the Campagnolo Warranty is worldwide so regardless of purchase, all Campagnolo Service Centres are obliged to honour the warranty on the product, no matter where bought, provided it *is* warranty and all the necessary documentation is provided.
