Weird Lightweight Chinese Steel Frame - CLR6200 Reynolds 520
waltthizzney
by waltthizzney
Has anyone seen one of these before? I must admit they look pretty good. The sizing/geo of the bike is a little crazy though? A large lines up with a 52cm Caad almost. The HT is stupid short on these
This Reynolds 725 frame looks nice too
https://www.ebay.com/itm/SEABORAD-Reyno ... SwldRZ9IXl
silvalis
by silvalis
There was a bit of discussion about this frame in here
viewtopic.php?f=3&t=113717&start=2580#p1314770
Chasse patate
waltthizzney
by waltthizzney
Do you understand the frame comparison? It seems like the geo of this bike is actually bigger than it appears? minus the small HT?
lone wheeler
by lone wheeler
For that price it looks like it's worth a punt! Just don't like the oversize seat collar. Geo looks ok, long and low.
waltthizzney
by waltthizzney
lone wheeler wrote:For that price it looks like it's worth a punt! Just don't like the oversize seat collar. Geo looks ok, long and low.
Does the Large line up with say a 52CM CAAD or FM066? Or am I missing something here?
prendrefeu
by prendrefeu
Your first geometry table is not the same as is posted for the Steel Frame in question, according to the eBay links in both this and the other thread.
silvalis
by silvalis
The geo of the large (535 tt) is in the ballpark of a 56 caad or similar L bike, as mentioned in the FM66 thread. See the bike geometry chart on the next page. I think the short TT lengths are due to the extremely short headtube + steep seat tube, hence reach is ballpark large sizing.
I noticed the other day an ebay aluminium frame with the same geometry as these steel frames - "marechal soul road bike"
Chasse patate
waltthizzney
by waltthizzney
silvalis wrote:The geo of the large (535 tt) is in the ballpark of a 56 caad or similar L bike, as mentioned in the FM66 thread. See the bike geometry chart on the next page. I think the short TT lengths are due to the extremely short headtube + steep seat tube, hence reach is ballpark large sizing.
Thanks, so what you are saying is due to the Seatube and Heattube angle, the reach is actually a lot longer than what is traditional with an effective TT of that size?
silvalis
by silvalis
Got curious again and plugged numbers into an online geo calc.
Note: I guesstimated the fork length. Ebay listing has dropout-brake bolt 352mm, so i guesstimated 363mm
In short, it's extremely long and low.
393/512mm reach/stack
Stick a crapload of spacers on and the large 535mm tt is ballpark medium 54cm.
Pic 1:
red: clr5200
green caad12 56
blue caad12 54
Pic2:
red: clr5200
green is a 54 R3
blue caad12 54
Chasse patate
ddsg
by ddsg
I don't understand why everyone just doesn't list stack/reach. Aren't they essentially the only measurements that determine fit?
silvalis
by silvalis
ddsg wrote:I don't understand why everyone just doesn't list stack/reach. Aren't they essentially the only measurements that determine fit?
most places do now.
reach, stack and seatpost angle.
Chasse patate
istigatrice
by istigatrice
head tube angle is also needed to determine the effective stem angle (e.g. a 71.5 vs a 73 degree head angle results in a ~3-5mm difference in handlebar stack and reach).
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
waltthizzney
by waltthizzney
thanks, still have no idea what size i am if I bought this bike lol
istigatrice
by istigatrice
I'd say silvalis is spot on, the large is similar to a 56 CAAD based on reach. The stack is much lower so it could have been designed for a +17 stem, or for people with really long torso and short legs. I'd suggest the small and medium frames would both be close to a 54/55 in terms of reach.
Another explanation is that they could be trying to save material (by using shorter tubes and steeper angles) to make the frames cheaper... Or they could just have no idea and those angles/lengths were what was available at the factory...
EDIT: I didn't see the second geometry chart, the above is based on the first geometry chart in the OP.
silvalis
by silvalis
After I did that second compare I didnt know what to think. You could have nailed it with the +17 stem...
Interesting, as I've spotted at least 4 different (3 steel, 1 alu) ebay frames with the same geometry so far (535tt, 74.5-75deg sta and 71.5hta, etc)
Chasse patate
