Venge seatpost tail light recommendations?
mvcap
by mvcap
I have the Blitzu tail light but it won't fit around a Venge seatpost. What do you use that fits the Venge seatpost? Thanks for the ideas...
Sent from my Nexus 6P using Tapatalk
Spez
by Spez
mvcap wrote:I have the Blitzu tail light but it won't fit around a Venge seatpost. What do you use that fits the Venge seatpost? Thanks for the ideas...
Cateye Rapid x3 works great for me.
Verzonden vanaf mijn iPhone met Tapatalk
IrrelevantD
by IrrelevantD
I have a Allez Sprint, which uses the same seatpost as a Venge. I'm going to throw in a +1 for the Cateye Rapid X3 and also suggest a Fly6 (camera/light). I'm running both on my Sprint with no issues.
MRM
by MRM
I use the Lupine Rotlicht fixed to the saddle rails. Eliminates the problem entirely (if you don't use a saddle bag).
cDaero
by cDaero
+1 on any of the Cateye Rapid X1,2,3 lights. Also Serfas makes some really nice lights and their universal mount works fine on the venge vias or gen 1 venge. They make an aero specific mount as well.
Valbrona
by Valbrona
Some of the Cateye lights fit to their saddle rail mount; other Cateye lights are not compatible with it. I use Cateye Rapid 5 with Cateye saddle rail mount.
gotgame
by gotgame
just get a saddle mount universal light or fix it with zip-tie
you can try also a silicon flexible light ( i'm using a cheap chinese one for a while and is ok )
Colnago e1 gazzetta dello sport - sz52s / Pinarello gan RS ulterga di2 - sz52 / Caadx 2019 vulcano green sz54
CrankAddictsRich
by CrankAddictsRich
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
climber8
by climber8
MRM wrote:I use the Lupine Rotlicht fixed to the saddle rails. Eliminates the problem entirely (if you don't use a saddle bag).
Rotlicht has always worked just fine for me on my Venge (original) and ViAS using the included strap. I use a saddle bag when I'm riding with the light, so a rail mount is not an option for me.
sun
by sun
I have an Allez Sprint as well. Venge seatpost and I run the Cygolite Hotrod 50 USB Rear Bike Light.
