Rotor 3D+ change shaft
Erwin
by Erwin
Is it possible to change the shaft from Rotor 30mm crank? I have a MTB 3D+ left and want to use it on a road bike, but the length of crank shaft is about 10mm longer than road version (q-factor would be very bad, especially on a BB30 68mm)? So, is the shaft glued to the non drive crank arm or can you open the "star-nut" on the non drive side?
dfischer1
by dfischer1
Pretty sure it's pressed and bonded in.
