What Happened to Over Torque?
Roel W
by Roel W
Do you really need that tool? I can buy a used 2017 Potenza cranckset for a reasonable price. I'm considering replacing my 2014 Athena cranckset for this one. However the dissambly may be impossible without the tools?
CANYON Ultimate AL 2010
CANYON Ultimate CF SL 2014
CANYON Ultimate CF SL disc 2018
Instagram @roeleur
Attermann
by Attermann
Potenza has nothing to do with over torque, potenza is power torque, and there where some talk about it being made in ultra torque, three different axle type, so no
bm0p700f
by bm0p700f
I can buy one easily as well of a distibrutor of such things and not graeme you wont find it online but that where calling a campagnolo freindly shop helps.
JD Whiskers carries good stock of campag parts and tools. this is who I go too.
Miller
by Miller
Attermann wrote:Potenza has nothing to do with over torque, potenza is power torque, and there where some talk about it being made in ultra torque, three different axle type, so no
Potenza is PT, yes (except see next comment). Assembly needs a 14mm hex, disassembly requires pulling off the LH crank with a pulling tool. This latter point has been the trigger for much interwebz angst.
Potenza HO, for the disc groupset, is, interestingly for Campag nerds, made with a UT spindle. 10mm hex for assembly/disassembly.
MayhemSWE
by MayhemSWE
Miller wrote:Potenza is PT, yes (except see next comment). Assembly needs a 14mm hex, disassembly requires pulling off the LH crank with a pulling tool.
The Potenza groupset has the only crankset following the newer Power-Torque+ standard which finally is self-extracting similar to GXP and others.
Miller
by Miller
Good point. The interwebz can finally relax.
Attermann
by Attermann
so it's only the HO versions that's ultra torque?
Valbrona
by Valbrona
Miller wrote:
Attermann wrote:Assembly needs a 14mm hex, disassembly requires pulling off the LH crank with a pulling tool. This latter point has been the trigger for much interwebz angst.
We've all got a 14mm hex lying around.
Miller
by Miller
We don't, no, but 14mm turns out to be an automotive size, look for a sump plug key on ebay, they're cheap.
