Campag reach adjustments for small hands
bikewithnoname
by bikewithnoname
Guys, I’ve just built up my girlfriends bike with campag chorus and she’s having trouble reaching the brake lever whilst in the drops as her fingers aren’t quite long enough, there doesn’t seem to be any reach adjust in the lever (2015 model year), do you know of any shims or hacks to bring the levers closer to the bar?
Last edited by bikewithnoname on Fri Oct 20, 2017 1:13 pm, edited 1 time in total.
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
jekyll man
by jekyll man
You're probably looking at a bar change, or adjusting the position of the ergo on the bars :/
AFAIK you can still only extend the reach not reduce it.
It's why traditionally women and campag dont mix.
Official cafe stop tester
bikewithnoname
by bikewithnoname
Not the answer I was hoping for but thanks. I was hoping there might be some sort of shim or block that might stop the lever returning all the way into the hood (hard to explain what I mean)
PinaF8
by PinaF8
Shimano levers have adjusting screw to minimize the reach for different hand reach. Not sure about campagnolo.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
Ironbarista
by Ironbarista
I remember reading about someone building up the area at the top of the brake lever with epoxy. Maybe give it a try.
*edit-found this. https://www.velocipedesalon.com/forum/f ... 18009.html
bikewithnoname
by bikewithnoname
Thanks! This might just work, I’ll give it a try
Mr.Gib
by Mr.Gib
2017 Campagnolo doesn't have reach adjustment either. Even with the most accommodating bar and careful lever placement your girlfriend will not be able to reach the levers from the drops. I can palm a basketball and I was shocked at reach with the levers in a reasonable position. I could just get my first knuckle on the levers. The lack of adjustment is unforgivable.
I have seen a few hacks. Both involve building up the plastic notch where the brake release pin contacts. I have seen it done with epoxy and also once seen a tiny screw screwed into the plastic notch to keep the lever from fully returning. Both a total bodge IMO.
