Rain overshoes
Attermann
by Attermann
What are the best overshoes now? Just need them to keep the water out, not much insulation is needed, what can you recommend?
ianeire
by ianeire
Velotoze
Squashednuts
by Squashednuts
velotoze do keep rain off
but I accidentally destroyed mine even though followed instructions
Currently using BBB neoprene which are okay in a light drizzle
In heavier rain they only keep feet dry for 5 minutes or so
uraqt
by uraqt
As most things in life it's not that simple or easy... There is a massive thread about it some were here. The short answer is ... you have to seal the top of the overshoe to your skin, and some people say you need a front fender.
I have cheap and expensive overshoes and the all work as long as I seal the top with a diving cuff, cut to size. I use a rear fender but no front. The question becomes how much rain for how long of a ride... 3 hour I would guess most "water proof" overshoes work, 5 to 6 hours in pouring rain then you are going to have to go velotoze or gore-tex. And then you are going to have breathability issues.
C
TonyM
by TonyM
Velotoze + tape on the holes of the shoes (and also above the screws of the cleats under the sole)
PinaF8
by PinaF8
Velotoze is awesome but it's a pain in the ass to put on and off.
Definitely tape the vents shut which helps during wet and cold season.
Best thing to do is have separate gears for wet and dry riding.
Good luck!
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
Shmitt
by Shmitt
What size of Velotoze do You recomend for Sidi road shoes size 44?
wedgie
by wedgie
I'm a size 44 in Gaerne. Bought size M Velotoze as recommend by LBS. Really nice tight fit but a nightmare to put on and even worse getting them off. Next time I'll get size L.
Wookski
by Wookski
White Velotoze but turn them inside out to hide the shitty logos
AJS914
by AJS914
What do you guys think about waterproof socks? I saw these on Ribble:
https://www.ribblecycles.co.uk/sealskin ... #pid=37953
TonyM
by TonyM
AJS914 wrote:What do you guys think about waterproof socks? I saw these on Ribble:
I tried pretty much everything last winter here, also the Sealskinz sock & overshoes, etc.....Nothing is better than velotoze 8)
One of big disadvantage of all these socks is that you cannot wear them in your (tight) summer shoes. So you end up having to use them in "larger" shoes or to have another pair of shoes; Then you can buy a "winter" shoe with Goretex etc....(which are usually not 100% waterproof).
The only disadvantage of the Velotoze is that they are not "breathable". But having said that I never had problems with cold feet even after a 5 hours rides in the rain 8)
Attermann
by Attermann
I’m actually tempted by the sealz overshoes, I have some overshoes with neoprene and then when it’s a bit colder, I have a pair of specialized winter shoes, so for me they are just for this crossover period
Broady
by Broady
Check out Spatz - https://www.spatzwear.com/
Local company to me, haven't tried them yet but by all accounts they're brilliant.
JohnHunt1990
by JohnHunt1990
Velotoze are great. You can wear neoprene over the top of them in winter to keep your feet warm and dry.
MXGimp
by MXGimp
Another vote for velotoze
