DT Swiss QR endcaps
ParisCarbon
by ParisCarbon
Im building my bike up and have 2 sets of DT Swiss DB wheels.. one is the R32 Clincher, and the other is the 38 Tubular.. I have installed both the supplied 135mm endcaps
On the tubular version the rotors are about .75mm more inboard than the clinchers... it doesn't sound like much, but on the clincher version the rotor is very close to the post mounts...
Is there anything I can do to get a little more space on the rotor side..I don't see how I could add a washer in there to add space because the endcaps seem to be one piece
pyrahna
by pyrahna
ParisCarbon wrote:Im building my bike up and have 2 sets of DT Swiss DB wheels.. one is the R32 Clincher, and the other is the 38 Tubular.. I have installed both the supplied 135mm endcaps
I'm going to start off with a silly question. Are the end caps symmetrical? If not try swapping them and see how that moves the wheel. Also, is the wheel sitting in the center of the seat tube?
ParisCarbon
by ParisCarbon
From what I recall wheel is sitting the same up the middle, the spacing from the cassette lockring to the frame looks the same... Im at work now... I popped the end caps out and reset them in and they pressed fully in..
ParisCarbon
by ParisCarbon
Ughh so DT Swiss mailed me back and said I am basically seeing the inherent desgin difference between a 240 and 350 hub...
jfranci3
by jfranci3
I had the same issue with my R32 DBs. I shimmed them with the centerlock washer from my other hubs to move the rotor out. You could also probably shim the endcap between the bearing and endcap.
I used the silver bit here - Image
https://novemberbicycles.com/products/c ... -pack-of-4
ParisCarbon
by ParisCarbon
Ok.. i need too move the r32 rotor in.. so prob best option is thin washer between bearing and endcap to push endcap out and move rotor in...
jfranci3
by jfranci3
Good luck finding the right shim/spacer. I think the OD is more important than the ID as the OD should carry the lateral load. I think those have a 6902 bearing, so thats a 28mm OD. I'd measure you end cap. Material should probably be Stainless or Delrin. Maybe call WheelsMfg.
ParisCarbon
by ParisCarbon
The bearing dimensions are 15X28X7 width..Im wondering if I swapped it to a 15X28X8 bearing if that would be better than messing with shims... the end cap isn't going to "snap" in but its also got no where to go because its going to be held in place from the compression of the Quick Release...
stormur
by stormur
Notorious issue with "3pawl" DT hubs; rotor to much outboard. I solved it using spacer between end cap and bearing. It was some copper washer grinded down to 0,65mm ( OD fitted perfectly , here small lip on endcap is your "size" ). Fitted, worked... no problems at all. For comparison Dicut rotor is more inboard than on dt350(spline) or 240 hubs.
Mark Twain
