Does Specialized still build with 62mm OSBB shells?
jever98
by jever98
OSBB on carbon frames was always 62mm wide, some of the narrowest out there. I was wondering if Specialized still builds their new frames like this?
Thanks
No longer in the industry
dvq
by dvq
I've got a 2018 Venge Vias Disc frameset with "OSBB" waiting to get built up -- I was surprised to find out it's just straight up PF30 68mm wide.
jever98
by jever98
Thanks - did you measure the shell? Because the crank interface, if I'm not mistaken, was PF30 with the OSBB shell.
Edit: looks like Specialized has indeed changed back to 68mm, according to some blogs out there.
Daniel1975
by Daniel1975
Well done. OSBB was useless bullshit. I'm hoping everybody goes to the new threaded BB.
dvq
by dvq
jever98 wrote:Thanks - did you measure the shell? Because the crank interface, if I'm not mistaken, was PF30 with the OSBB shell.
Yes, measured shell. Even double checked because I was sort of surprised.
Do you have a source for those blogs that stated this? I can't find anything.
Digger90
by Digger90
Daniel1975 wrote:Well done. OSBB was useless bullshit. I'm hoping everybody goes to the new threaded BB.
Touché. Threaded BB's will come back! :D
Cannondale deserve to be crucified for inflicting useless, POS, only-of-benefit-to-accountants, creaky, press-fit crap on the world.
dvq
by dvq
Update to my earlier response, took some closer measurements.
https://imgur.com/a/hNN2P
Measured at the cups ~ 68mm
Measured at the shell ~ 66mm
Measured at the outer races of the bearings ~62mm
Not sure if this means I need spacers or anything for a regular bb30 crank.
jever98
by jever98
That's very odd - looks like they retained their narrow bearing stance on a wider shell? As far as I know 68mm is the normal bearing stance.
Best
