New Chorus RD....bent??
Boshk
by Boshk
thanks guys. Will do on the jockey wheels.
I'm ordering in a Lezyne Drive Chain 11spd tool....basically for campy chains.
I'll see if I can get hold of a spare link and pins.
I'll go over the whole installation again when I get time BUT I did go for an hour ride today.....totally smooth from the RD....from my limited experience.
Campy is very different from Shimano.....very 'clunky' sound when shifting but the multiple shifts are very very nice.
When the chain is at its most efficient positions....around the 5th to 7th cogs....its super smooth and silent, I try never to really cross chains.
50-12 is way more than enough for me....only used it on descents
34-29 is a nice 'get out' cog for me.
The only annoyance I have with this new Chorus is actually the FD now. Shifting into small ring is easy, super smooth 100% of the time. The trim function if thats what its called is nice.
Shifting into the Big ring is a hit and miss.....grinds a lot....but I assume thats just due to the tension in the cable. Don't have time to deal with it atm but will do before the next ride, and yes, I will RTFM haha and not youtube it.
Another problem is the thumb levers when on the drops, my handlebar sucks. I just can't reach them comfortably, thumb is strained every time.
I can't for the life of me get the same measurements as Bianchi's website for the 42cm size bar....its states 126mm drop and 77.4mm reach.....
My own measurement centre to centre...Width=42cm Reach=90mm Drop=140
Stem is 100mm.
Deda Zero100, Ritchey WCS Logic? any other suggestions I should look into?
Colnago C60
AJS914
by AJS914
I'm glad you got the rear sorted out.
I also bought that Lezyne chain tool because they claimed Campagnolo support. It left a kink the chain when I shortened it. The peening for the Campagnolo link worked ok. I thought maybe I did it wrong. They don't have a manual or any usage info on their web site so I wrote customer service. No response.
Boshk
by Boshk
AJS914 wrote:I'm glad you got the rear sorted out.
Are you still using it?
The price difference between the Lezyne and Camp is huge.
Colnago C60
dj97223
by dj97223
The Pedro's tool works all Campag chains and is much less than the Campag tool.
Alexandrumarian
by Alexandrumarian
Speaking of chain tools, I cheaped and got a Topeak "all chains" tool. Pretty bad, the pin rattles and I was pretty sure I had botched the peening. Seems to hold so far but I really wish I got a better tool.
As for the FD, it has been very tricky for me too. It was working OK on the road, but on the stand a lot of grinding while half engaged over the big ring, and most of the times it would fall back and even off completely. On the road I could keep the lever pressure high for a second and it would shift OK. All this in the big cogs - worked better/easier in the middle of the cassette. Still, very disappointing considering my wife's Tiagra lifts from small to big effortlessly on the stand.
I found out I had the Campy inline adjuster all wrong. It has to be knurled part down (towards frame not bars) and with a metal ferrule at the knurled end. The bad install made a mess of the housing end, it is amazing it could work at all. After I fixed this it got a lot lot better. Another useful change was to add a washer at the anchor bolt to reduce friction between cable and outer pivot. Campy washer is pricey for what it is and out of stock in most places so I ended up making one myself.
wilwil
by wilwil
If the chain was shorter it would probably rub on the jockey cage in 34/12
AJS914
by AJS914
I still have it. I'm going to be ready this winter for a new chain so I'm still deciding what to do. I'll probably try it again and be more careful when breaking the chain.
Boshk
by Boshk
dj97223 wrote:The Pedro's tool works all Campag chains and is much less than the Campag tool.
Thanks!
Looks like the Pedros Pro Chain Tool 2.0 NEW version is campy compatible....at $75
The original Pro Chain Tool 2.0 may not be??
They also have a Tutto Model....which is just below the Camp Tool price
Colnago C60
wilwil
by wilwil
The FD needs quite a bite of cable tension. It also needs to be in exactly the right position. It may not be possible to have the chain on the big ring and the big cog without rubbing on the inner plate of the FD. Its better to sacrifice that to achieve good shifting.
dj97223
by dj97223
Thanks!
I have the Tutto; it works with 10 and 11 speed (also 9, I believe) I have both 10 and 11 speed bikes, so I need that flexibility. When I bought it, it was substantially cheaper than the Campag tool. A quick online shop shows is is still about $100 less.
glepore
by glepore
If a shop sent you the bike like that, find another shop. The new Campy fd's are fiddly to set up right-Calnago here can vouch for this. A good shop would have checked the hanger, chainlength, b pivot. Lots wrong here. Excusable for a diy mechanic, not a shop.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
bikerjulio
by bikerjulio
glepore wrote:If a shop sent you the bike like that, find another shop. The new Campy fd's are fiddly to set up right-Calnago here can vouch for this. A good shop would have checked the hanger, chainlength, b pivot. Lots wrong here. Excusable for a diy mechanic, not a shop.
I agree, and asked the question in my first post here.
Has this shop ever worked on Campy equipment?
If a shop sent it out like that they did an extremely poor job.
While not wanting to start the link vs. pin debate all over again, I have to say that in a case like this when chain length is critical, it's much easier to use a link and work down in length if necessary. It's better to shorten a chain than lengthen it.
There's sometimes a buggy.
One.
Boshk
by Boshk
I assumed they have experience with Campagnolo because they do sell the whole range. As to whether they actually have an official campy qualification is another matter.
Even from the Campagnolo website, it only states Iron Ore Company as the Service Center in Hong Kong. They are just an importer/distributer. Its a bit weird how things are done here. You guys have Campy Code shops, Pro Shops where they are licences.
Anyway, so I said, I'll recheck the FD and chain again. I could just buy a Record chain and replace my Chorus since most say the Record is better. I just need to get a campy specific chain tool, either Pedros or Lezyne.
Colnago C60
