Saddle height and agility
dedobike
by dedobike
How does saddle height affect agility? a lower saddle means more agility or is it exactly the opposite?
With these measures, saddle height should have (roughly)
h 176cm
inseam 82.8cm
foot 45 (eu) 28.7cm
Saddle height
73cm, 73.5cm or 74cm or ?
Tanks
wingguy
by wingguy
Agility like cornering? Then yeah, a lower saddle means more agility. But you 100% should not set your saddle height based on that.
Further, no-one can tell you what your saddle height should be to that degree of accuracy based only on an inseam measurement. You can get to a cm or so ballpark from it but beyond that it's about shoes, pedals, cleat position, and most importantly you in motion.
Matt28NJ
by Matt28NJ
Define agility.
dedobike
by dedobike
Matt28NJ wrote:Define agility.
make a bike ride with a rpm range between 80 and 90, now with 73 cm saddle height it seems to be too low and uphill I struggle to get agility
wingguy
by wingguy
What made you set it at 73cm to begin with? If you think it's too low, try it higher or get someone to look at it.
If it feels too low, it's probably too low, especially if you're getting a concentrated burn on the quads. But no-one can accurately tell you how high it should be without seeing it.
dedobike
by dedobike
wingguy wrote:What made you set it at 73cm to begin with? If you think it's too low, try it higher or get someone to look at it.
The 73 cm saddle height was set during a biomechanical visit but another visit made me saddle at 74.2 so I'm undecided. The length of the feet is higher than average so I would think I would be closer to 74 cm rather than to 73
Inviato dal mio Redmi 4 utilizzando Tapatalk
TobinHatesYou
by TobinHatesYou
Saddle height has nothing to do with “agility.” Something may be lost in translation. Higher saddles tend to also be pushed forward a bit. Your quads will be worked more. A lower saddle will work your glutes more. A lot of people overwork their quads and suffer from muscle fatigue that is mistaken for knee pain, so I always prefer people ride with too low of a saddle than too high.
wingguy
by wingguy
dedobike wrote:The 73 cm saddle height was set during a biomechanical visit but another visit made me saddle at 74.2 so I'm undecided. The length of the feet is higher than average so I would think I would be closer to 74 cm rather than to 73
Which one is better to ride?
3Pio
by 3Pio
Im 175cm, 82-82.5 insea, 43 foot (27.5-28.0) and my saddle is set on 72.7 cm with 52mm setback if this help u.
Im sure 73 cm and 74.2 setting was adjusted with different setback. Try both settings for a while, including longer rides, so u;ll realize which one feel better..
TobinHatesYou
by TobinHatesYou
I'm 178cm with a 81.8cm inseam and my saddle height is 71.7cm with 8.9cm of setback.
pdlpsher1
by pdlpsher1
I'm 170cm tall, 80cm inseam, 70cm saddle height and 5.5cm setback.
wingguy
by wingguy
TobinHatesYou wrote:I'm 178cm with a 81.8cm inseam and my saddle height is 71.7cm with 8.9cm of setback.
That's fairly unusual. Very difficult to achieve on most bikes (assuming a relatively normal length saddle), to be honest!
TobinHatesYou
by TobinHatesYou
Saddle's an S-Works Romin Evo, so it's 26cm. I think most saddles are around 27.5cm or so?
dedobike
by dedobike
Saddle's and S-Works Romin Evo, so it's 26cm. I think most saddles are around 27.5cm or so?
In order to compare saddle backwardness as a reference point, it is not necessary to take the tip of the saddle (each saddle has a different length) but its anatomical center is located where the saddle surface is wide 7.2cm. Qunindi saddle saddle by convention is the distance between the center movement (c / c) and the anatomical saddle center
3Pio
by 3Pio
I have also Romin Evo Pro but old model (2014) (on the other bike which i dont ride it at all since i bought C60, but this season will be my Winter Bike, so today probably i'll check the position i need there). It's 27 cm long.
And also look to me like too much setback in ur position. But maybe ur femurs are very long, or it's compatibile with ur anatomy. Saddle setback/height is not always the same for everyone having same inseam.
Before i done Rettul fitting, i was using lower saddle position with more setback. After Rettul fitter put me with less setback and saddle higher.. Much more comofortable, much more power on climbs and sprints, and much more effective...But again.. It's personal thing..
