9170 funnel adapter
ParisCarbon
by ParisCarbon
I have a set of Dura Ace 9170 shifters (only the shifters) arriving shortly for my CX bike as I am using 785 post mount brakes..
Does anyone know if those individual levers come with the funnel adapters?? I can't see anywhere that says yes or no.. I can't find the adapter anywhere in North America.. looks like without the adapter you can't bleed the brakes...
Thanks in advance...
kode54
by kode54
if you only get the shifters and not the kit, it does not come with the funnel. you'll have to buy the funnel and the bleed kit separately. the kit has hoses and the funnel with mineral oil.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
lovemyway
by lovemyway
kode54 wrote:if you only get the shifters and not the kit, it does not come with the funnel. you'll have to buy the funnel and the bleed kit separately. the kit has hoses and the funnel with mineral oil.
This is not true, I got the two separate levers and one of them (if I remember the right one) comes with the adapter.
kode54
by kode54
if its the retail box version...its possible. if OEM in polybag...no.
MisterEd
by MisterEd
^ this is the part number etc, if that helps your search
ParisCarbon
by ParisCarbon
I got the levers from ProBikekit.. so not sure what version will come...
I ended up ordering the funnel adapter from Germany...its the only place I could find it.. by the time it gets to Canada my CX season will be over... I did ask them if I could pay more for shipping to get it DHL 2 day.. for something that small I can't imagine it being more than $20
Im assuming the adapter is not included..
Im tempted to buy 2 funnels and try and frankenstein the 2 together somehow to make this work.. I figure If I can cut the bottom of one off and get some kind of tubing over it, and then link it to the other funnel... thinking about using fuel line tubing like I use in my RC airplanes.. its flexible enough to slide over but won't leak...
Disappointing a required piece isn't included and I have to order it from the other side of the world...
dmcgoy
by dmcgoy
I freaked out when I got my 9170 levers (retail, USA) and I couldn't find them in the first box I opened. Later I found the adapter in the RIGHT (rear) box. So you are only screwed if you buy the front only.
ParisCarbon
by ParisCarbon
Thats good to know... I ordered from PBK... am a little concerned now whether I am gonna get a retail box or just a lever wrapped in plastic.. I'd assume everything would be there.. and I have a L and R coming... fingers crossed!!!!
ParisCarbon
by ParisCarbon
Just a follow up as my parts arrived today.. the RIGHT lever did include the funnel adapter.... I think someone earlier said the same..
Weird.. so I have a funnel coming now from Germany as a spare... :noidea:
justaute
by justaute
FWIW...9170 levers seem to also require a different Flange Connecting Bolt. Parts #3 and #4 in the below linked PDF. I can't find them right now. Sucks in that I have the levers but not the connecting hardware.
http://si.shimano.com/pdfs/ev/EV-ST-R9170-4079.pdf
ms6073
by ms6073
justaute wrote:Sucks in that I have the levers but not the connecting hardware.
The Joint Support Ring (Parts 3) should be attached to the shifter, whereas the flange is supplied with the SM-BH90-JK-SSR Disc Brake Hose Kit, not the levers.
justaute
by justaute
Thanks. I'll look into it. I'm ware of the BH90 kit, but didn't know there's a specific kit for 9170. Will tell my shop. That said, it seems as though nobody has this kit in stock.
dmcgoy
by dmcgoy
Universal cycles:
https://www.universalcycles.com/shoppin ... p?id=41870
justaute
by justaute
Universal cycles:
Thanks. Found it after some looking. I wish Shimano would just sell that Flange Connecting Bolt. The BH90 hose kits are already widely available. I guess it just wants us consumers to spend more money.
