What power meter on sworks 2018 sl6?
dedobike
by dedobike
Which power meter do you recommend to mount on a sworks sl6 2018 bike? At the moment I have not yet ordered any cranksets because I have to choose the power meter model..the budget is 1400 €
Drizzle
by Drizzle
Quarq?
dedobike
by dedobike
Drizzle wrote:Quarq?
Quarq but what version? with its original cranksets?
For 1300 Euro I had found this model with sworks carbon gasket
https://www.quarq.com/product/quarq-for-specialized-power-meter-spider/
But it's no longer in production is the old old ant quartz model, I read that gave problems. And somewhere out of the shimano power meter
morganb
by morganb
Power2Max NGeco will work with the new style S-Works cranks. Cheaper than a Quarq and in the same level of quality if not better. Also gives you the option to go 110 Asymmetric if you are running a Shimano drivetrain.
dedobike
by dedobike
morganb wrote:Power2Max NGeco will work with the new style S-Works cranks. Cheaper than a Quarq and in the same level of quality if not better. Also gives you the option to go 110 Asymmetric if you are running a Shimano drivetrain.
But this way I do not have the sworks cransket, the only way to have it is to take it with the quarq meter otherwise I'm going out of budget (ng eco + sworks crankset) >>>> 1300 €
fogman
by fogman
What groupset will you be using? Are you looking at spider-based, left crank arm-based, or pedal-based power?
It's all downhill from here, except for the uphills.
AndreLM
by AndreLM
Specialized S-Works Carbon Road Crankset W/ Quarq 52/36 110BCD 175MM BB30 - Price Drop
https://r.tapatalk.com/shareLink?share_ ... are_type=t
I don't know the guy. Just saw in the FS
dedobike
by dedobike
fogman wrote:What groupset will you be using? Are you looking at spider-based, left crank arm-based, or pedal-based power?
The group I will use is a Shimano Dura Ace 9100 DI. Can the new quarq dfour 91 be installed on the original shimano pedal or do you need to take the Quarq crankcase?
I prefer a power meter model on crankset (srm, quarq, power2max)
morganb
by morganb
S-Works crankset is $400 in the US, NGeco is $490. Eve if the cranks cost more in Europe it shouldn't be double the price.
dedobike
by dedobike
Europe 700€ --- 900€
sun
by sun
This it he new Dzero for Specialized. https://www.quarq.com/product/quarq-dze ... qk27je0edt
dedobike
by dedobike
sun wrote:This it he new Dzero for Specialized. https://www.quarq.com/product/quarq-dze ... qk27je0edt
good but I would rather it would be marketed at the end of October if I'm not mistaken?
what are the differences with the old version?
sun
by sun
I'm not seeing an October date. The main differences are probably Bluetooth. They started adding the temp calibration on their later models. They probably refined the hardware a bit on the newer ones as well.
dedobike
by dedobike
sun wrote:I'm not seeing an October date. The main differences are probably Bluetooth. They started adding the temp calibration on their later models. They probably refined the hardware a bit on the newer ones as well.
should it already be available? but the quarq dzero can i mount it on tarmac sl6 if i do not wanna wait for that specialized?
sun
by sun
It says you can add to cart right now. You could order the whole dzero crank and power meter. You would use the BB30 version.
