Sram Red 11 Brake / Spring holder missing
ukracer
by ukracer
Hi ,
When stripping and cleaning my brakes i have somehow lost the slotted screw / pin that holds the return spring in place
Its the part that stops the lateral play of the spring at each end.
I have searched for spares but couldnt find anything or even the correct name
Can anyone please help or even tip for alternative solution?
kkibbler
by kkibbler
You could try screwing in a slotted screw from the other side, ending with the slot vertical. If the slot is not wide enough to seat the spring, widen with a file.
topflightpro
by topflightpro
Call your bike shop. I believe Sram sells a replacement kit.
I lost the cable barrel on mine, and I think the replacement pack came with those too.
ukracer
by ukracer
thanks for the advise
