Red 22 ( 2016) b-bolt issue (?)
stormur
by stormur
Noriced recently slight play on b-bolt. Red22 rd, around 2000km, short cage. Checked other rd's @home ( DA, Ultegra R800 )- there's not any kind of play there.
Question ; is it beggining of the end, or just such design ( spring-less for Red ) ?
Mark Twain
pyrahna
by pyrahna
stormur wrote:Noriced recently slight play on b-bolt. Red22 rd, around 2000km, short cage. Checked other rd's @home ( DA, Ultegra R800 )- there's not any kind of play there.
SRAM road rear derailleurs are a different basic design than Shimanos. They do not have a spring in the b-knuckle. The tension is based completely off the chain tensioner.
NiFTY
by NiFTY
Not sure how the b bolt can develop play. It is just a bolt in a thread pushing aginst the hanger. The pivots of the parallelogram can develop play but i have not experienced this personally. I have personally had 3 sram rear derailleurs develop significant play on the axle of the pulley cage - 1 to failure (which killed a lightweight meilenstein), all had poor shifting across part of the cassette range as a symptom.
stormur
by stormur
i don't mention non existant spring tension, rather play side-by-side. other rd's sit firm on hanger, Red has tiny play.
Mark Twain
pyrahna
by pyrahna
stormur wrote:i don't mention non existant spring tension, rather play side-by-side. other rd's sit firm on hanger, Red has tiny play.
There should not be any side to side play from the hanger.
stormur
by stormur
Sorry foe sarcasm, but just have to ; BLESSED THOSE WHO READ WITH UNDERSTANDING.
Quotting myself : "slight play on b-bolt " B-bolt, NOT hanger.
PS : problem solved, derailleur replaced /warranty.
Mark Twain
