1x conversion
illlili
by illlili
Hey guys, after months of dead-end research Iv decided to ask the community here for advice with dropping the small ring.
Bike: '17 giant propel, ultegra 52/36 - 11/23.
My goal is to upgrade the rear derailleur and accompanying right side shifter to red e-tap and to eliminate the front inner chainring and front derailleur.
The cassette is not original and im very happy with it as I ride only on the flats. Small ring has only been seen when the bike is stored to de-tension the rd.
Would a 52t chainring make it as if nothing was changed as far as gearing? I notice most change both the front and rear gearing to accommodate.
Lastly, any recommendations on a new crankset/ring etc?
Thanks
James
moyboy
by moyboy
Check here to see the comparisons of two different setups.
http://www.gear-calculator.com/
Also i do a 1x SRAM Force 1 with a 10-42 XX rear cassette and a 46 on the front. Covers the whole range like a compact and climbs really well.
Marin
by Marin
Do you ever need 52-11?
I am running a 46t front ring and 11-30 in the rear, but I am riding hilly terrain.
Maybe a 50t front would be fast enough for you?
bm0p700f
by bm0p700f
i got a garbaruK 52T asymmetric ring in narrow wide format. works fine but 1x is a bit more noisey with this ring but the ring itself retains the chain very well.
As for the chainset to use a 5arm campagnolo carbon record square taper of course.
