Colnago C60 tire compatability
mnmasotto
by mnmasotto
I have a 2016 Colango C60. I would like to run Continental Grand Prix 4000 tires in size 25mm. I know these tires (25 mm) will not fit on my C59 or Masterlight. Does anyone have any experience with these tires on this particular frame.
dkrissinger
by dkrissinger
Yes, they will work.
torinb
by torinb
Yes they work, but you couldn't fit anything wider than those.
damond
by damond
what about the C60 with DM brakes? How wide can it handle?
Boshk
by Boshk
Pirelli P Zero's are out , 25mm :D
Colnago C60
wedgie
by wedgie
Conti Gp4000 25mm fit fine on the front, but only just give enough clearance on the rear. It depends on the wheels you're using but the tyres are very tall. I use campag boras and have about 2mm vertical clearance to the rear brake bridge so tyre debris is an issue particularly in the wet.
Johnnysmooth
by Johnnysmooth
wedgie wrote:Conti Gp4000 25mm fit fine on the front, but only just give enough clearance on the rear. It depends on the wheels you're using but the tyres are very tall. I use campag boras and have about 2mm vertical clearance to the rear brake bridge so tyre debris is an issue particularly in the wet.
Ditto, but I'm riding open tubular corsa cg
It only hurts if you think.
