True. The biggest offenders are tubeless rims. They rely on a friction fit with the tire bead and when too tight, tension drops. The degree this happens depends on the rim and tire chosen.BdaGhisallo wrote: ↑Wed Sep 26, 2018 12:49 pmIs it safe to assume that this is not much of a problem with tubular rims?
ENVE SES 4.5 with ENVE hub => brake rub
Indeed and that’s one of the benefits of Mavic UST system tolérances are controlled on both rim and tire. Then minimise tension drop that only become a problem if under rider weight and lateral stress you emd up with a slack spoke.ergott wrote:True. The biggest offenders are tubeless rims. They rely on a friction fit with the tire bead and when too tight, tension drops. The degree this happens depends on the rim and tire chosen.BdaGhisallo wrote: ↑Wed Sep 26, 2018 12:49 pmIs it safe to assume that this is not much of a problem with tubular rims?
- Moderator
Bit of a thread dig, anyone having chain suck issues with the seals in these?
Using Tapatalk
- VTR1000SP2
I did but in my case it was a faulty hub which got warrantied.Nefarious86 wrote:Bit of a thread dig, anyone having chain suck issues with the seals in these?
Focus Izalco Max - 4.84kg without pedals
Cervélo Áspero - 8.28kg
Trek Madone SLR Rim - 7.73kg
Standert Triebwerk Disc - 8.47kg
- Moderator
What was the cause? Have one here playing up...VTR1000SP2 wrote:I did but in my case it was a faulty hub which got warrantied.Nefarious86 wrote:Bit of a thread dig, anyone having chain suck issues with the seals in these?
Using Tapatalk
- VTR1000SP2
Flanges were wonky.Nefarious86 wrote: ↑Mon Dec 24, 2018 1:49 pmWhat was the cause? Have one here playing up...VTR1000SP2 wrote:I did but in my case it was a faulty hub which got warrantied.Nefarious86 wrote:Bit of a thread dig, anyone having chain suck issues with the seals in these?
Where the freehub sat against the hub body was out of tolerance and would generate enough friction to jam it up.
