Black bike, yellow stem?
RimClencher
by RimClencher
Maybe get some fluorescent/reflective yellow tape as well and experiment a bit. Because safety is always fashionable. :)
Lieblingsleguan
by Lieblingsleguan
I wouldn't do it, because the yellow of the stem is not going to match the yellow lines on the frame. On an all black frame, the stem would be ok.
I would go with the yellow stitching on black bar tape and additionally, you could look for another small touch of yellow. Maybe the outer cables of the rear brake where it exits the frame to the brake and of the rear derailleur where it exits the chainstay. The Shimano yellow outer cable is quite a non-fluo darkish yellow.
I'd also like white bar tape on the frame, but you'd also need a white saddle then and you'd have to change the tape like every 4 - 10 weeks.
gravity
by gravity
Yellow stem, yes. But not with gumwall. The yellow/tan colour of the tyre wont match the yellow stem.
srshaw
by srshaw
Black and yellow is a bit lance Armstrong. Not a look I would personally try to emulate.!
Lieblingsleguan
by Lieblingsleguan
srshaw wrote:Black and yellow is a bit lance Armstrong. Not a look I would personally try to emulate.!
And you might be hated by Browns Fans in the US or by Schalke 04 Fans in Germany :D
r33prman
by r33prman
All black with a touch of color from the Fluor stem will look great. I'm a yes!
Alexandrumarian
by Alexandrumarian
Thank you all! Now I will disappoint half of you and say I went for black. The radioactive color seemed too much and indeed not a perfect match to the rest of the yellow accents.
Also did a first quick run with the stitched thing. Rather pleased. Used my favorite tape (cheap basic but perfect for my hands Deda) and I'd say it would go better with a less compressible or stretchy tape. When pulled hard the thread sinks in and becomes less visible. Leather would work perfect but I am not a fan of the feel. Next time will try to stitch over again so I get a thicker pattern. Thread is kevlar btw, yellow is its natural color :) Expensive stuff but sitting unused for a few years (I used it in the past to DIY mountaineering overboots)
BTW stem came a bit overweight (130g vs 125) but old stem was over too, 171 vs 163 claimed. Maybe they weight them without bolts :)
