I'm having issues pairing my pioneer powermeter with my Wahoo Elemnt
Does anyone here have any experience with pairing a Pioneer powermeter to a Wahoo computer device or getting it into ANT+ mode?
It is dual sided and I can't seem to get it into ANT+ mode.
I tried all methods that pioneer provided such as this manual https://www.pioneerelectronics.com/ephox/StaticFiles/PUSA/Files/Cycle%20Sports/Pioneer%20Cycle%20Sport%20Quick%20Guide%207-7-16.pdf
Both side shows up with a solid green light. I spin the cranks 3-4 rotations, held the push button for 3 seconds, and it just doesn't seem to go into ANT+ mode or blink orange for me.
If anyone have any solutions, it will be greatly appreciated.
I might have to purchase a Pioneer computer if all fails.
djwalker wrote:I have a Pioneer powermeter and an Elemnt. I also have a Pioneer computer. What I did was put it into powermeter mode using the Pioneer computer. Then it paired just fine with the Elemnt.
Did you ever have to pair the elemnt with the powermeter again after every ride?
I paired my Pioneer once (just like all of my sensors) and it has stayed paired since then. I just turn the computer on, get on, and ride. The powermeter wakes up after a few seconds and then everything is good. I don't know what would happen if you start the computer and then don't wake up the powermeter until a while later. The computer might stop looking after some amount of time. So, I would rotate the cranks to wake up the powermeter when the computer is powering up if you were worried about it.
Only the software from the last 2 years 2015-05-01 in the crank and display works with the pioneer display to switch mode.
The old way was with the button in the battery compartiment.
2.2.1.3 Confirmation of the actual sensor mode.
When the batteries are installed, the LEDs on the left and right transmitters light as follows depending on the actual
sensor mode.
• When it is in pedaling monitor mode: The LEDs light green for 10 seconds
• When it is in dual power meter mode: The LEDs light orange for 10 seconds
• When it is in single power meter mode: The LEDs blink orange for 10 seconds
copied from the manual
sensor mode.
The mode can be switched in two ways
[Method 1] Switch by pushing the push switch in the right transmitter
[Method 2] Switch the mode on SGX-CA500
2.2.1 [Method 1] Switch by pushing the push switch in the right transmitter
When using a Cyclocomputer from another manufacturer, switch with this method.
2.2.1.1 Loosen the screws on the right transmitter cover and remove the cover.
2.2.1.2 Replacing the batteries of the left and right transmitters. The operation is enabled for 5 minutes after the batteries are
installed. Switch within 5 minutes. If more than 5 minutes elapse, re-install the batteries
of the left and right sensors.
tomee wrote:i had the pioneer dual sided on a bike and wanted to split them up to put on another bike.
I did what djwalker said and put them both into power mode instead of pedalling monitor
Woah! You just made me realize that I can have power on both my bikes if I split the LT arm up. How off/accurate is your power reading with just 1 left arm on 1 bike and the Crank on the other bike? Compared to when you had duel leg on the same bike. Considering the system was made to calculate duel.
MomentumR5 wrote:tomee wrote:i had the pioneer dual sided on a bike and wanted to split them up to put on another bike.
havent noticed anything different power wise.
although i do have a more predominant left leg, so teh bike with the right sided PM might read a little lower but im OK with that.
Find someone or a shop with the Pioneer head unit and use that to switch it into dual-Ant mode. Should work normally after that.
Also take the opportunity to update the meter’s firmware. It is a slow process and requires a relatively new battery in the power meter.
tomee wrote:MomentumR5 wrote:tomee wrote:i had the pioneer dual sided on a bike and wanted to split them up to put on another bike.
Ha. My LT is stronger too. Is this a fit issue?
Good news, the latest Pioneer Computer update can change the % so if you are running a single side Pioneer, you can adjust the % for that leg.
Darceking wrote:tomee wrote:MomentumR5 wrote:tomee wrote:i had the pioneer dual sided on a bike and wanted to split them up to put on another bike.
What is the latest software update? I've looked but nothing is new for the Ca500 or the Pioneer PM.
Version of firmware : 20170927.02.57
You can check the version of your firmware as described below.
Confirmation procedure : [Settings] - [System] - [Firmware Version]
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
2019 SCOTT SPARK RC 900
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
