2018 S-Works Tarmac Disc
ParisCarbon
by ParisCarbon
tnkn wrote:
Thu Nov 15, 2018 10:19 am
Hi all,
I've just bought a 2019 S-Works Tarmac Disc frameset and would like to run my Dura Ace 9100 chainset.
Would the chainset fit with the CeramicSpeed BB straight out of the box or will I need a new BB?
Thanks for your help.
Highly recommend this:
https://www.ceramicspeed.com/en/sport/s ... mano-road/
The reducer cups were driving me nuts with the creaking on my SL5... worked perfect for a while then just got annoying...
Switched to BB I posted above and SILENCE!!
tnkn
by tnkn
Hi all,
I'm undecided whether to go ahead and install the ceramic speed bearings plus wheels mfg Shimano adaptors that came with my frameset or purchase a new BB altogether to try and avoid the dreaded creak. (https://www.sigmasports.com/item/Wheels ... ranks/EM25)
Could I use the CS bearings in a third party bottom bracket or should I see what I get for them on eBay?
Thanks for the help
Stendhal
by Stendhal
tnkn wrote:
Wed Dec 05, 2018 2:04 pm
Hi all,
Thanks for the help
I have the SL6 rim which should have the same BB. I needed to adapt to a SRAM GXP crankset (also 24 mm). Originally, the shop installed a Praxis Works one piece adapter (see their site). No creaking but a bit heavy (144g) and not ceramic if you think that matters. (Smart people here say otherwise, but I was used to ceramic.) I switched to a cbear BB30 to GXP BB. It is lighter at 93g and ceramic. So far no creaking, maybe just a hint of a clicking noise (not sure). I sold the Ceramicspeed bearings that came with the frame on eBay for more than the price of the cbear.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
tnkn
by tnkn
I think I'll shell out for a new BB and stick the bearings on eBay. I'd rather the build was right from the start rather than using various adaptors etc. The adaptors alone were £25 so it's a good chunk of the money towards a new BB.
P.s. I get a slight click from time to time on my Argon 18 Wheels MFG BB30.
Stendhal wrote:
Thu Dec 06, 2018 4:08 am
parajba
by parajba
I have a Quarq DZero GXP. If I buy an SL6, what is the lightest and best adaptor money can buy? Would I be missing out on any of the functionality of the SL6’s bottom bracket by using an adaptor? Would it be better to sell the Quarq and buy the correct model for the SL6?
Jugi
by Jugi
The best "adapter" for a GXP Quarq DZero is most likely a DZero compatible BB30 crankset. I'm not sure how much DZero compatible cranks cost as is, but as you have the powermeter spider already, that would lead into a simple and light configuration. All additional parts increase the likelihood of a creak.
cycleboyco
by cycleboyco
Jugi wrote:The best "adapter" for a GXP Quarq DZero is most likely a DZero compatible BB30 crankset. I'm not sure how much DZero compatible cranks cost as is, but as you have the powermeter spider already, that would lead into a simple and light configuration. All additional parts increase the likelihood of a creak.
That’s a great suggestion. You can purchase crankarms directly from Quarq by calling them-they are about $425 USD-I had BB30 and was going to GXP. Their customer service is great.
Matt28NJ
by Matt28NJ
tnkn wrote:
Thu Dec 06, 2018 10:09 am
"Shell" out for a new bottom bracket? I see what you did there.
sfo423
by sfo423
Anypone know if the CLX 50 wheel stickers / labels are removable? Looking at a pair of LE wheels and hate the logo color.
scale29
by scale29
They're under clear coat.
sychen
by sychen
They actually look pretty nice with the turbo cottons..
Need an appropriate frame colour scheme to match!
lovemyway
by lovemyway
Where did you get the wheels with yellow stickers? Aftermarket?
parajba
by parajba
cycleboyco wrote:
Thu Dec 06, 2018 6:09 pm
Sorry I am not sure I follow. This is the one I have:
https://www.sigmasports.com/item/Quarq/ ... Meter/ENWU
Does that mean that I could replace just the crank arms and that would make my Quarq compatible with BB30?
cycleboyco
by cycleboyco
parajba wrote:
Fri Dec 07, 2018 10:51 am
Yes-you can buy the Quarq BB30 crankarms/spindle without the DZero spider directly from Quarq-it's not on their website. I was able to do this by calling their customer service. Not sure how difficult it is to remove/reattach the spider, as I ended up changing my mind and returning the GXP crankarms.
ryanw
by ryanw
Don't SL6's (S-Works) ship with a CeramicSpeed PF30 BB with Shimano 24mm adapters?
If so, just buy a Quarq BB30 DZero Carbon and remove the adapters you're currently running with the Shimano cranks.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
