2018 S-Works Tarmac Disc
Hi all,
I've just bought a 2019 S-Works Tarmac Disc frameset and would like to run my Dura Ace 9100 chainset.
Would the chainset fit with the CeramicSpeed BB straight out of the box or will I need a new BB?
Thanks for your help.
Ax-lightness VIAL evo 3,89kg - sold
Lightweight Urgestalt Disc 6,86kg - sold
Specialized S-Works Tarmac SL6 Ultralight 6,16kg - sold
Specialized S-Works Tarmac SL7 6,93kg
Specialized S-Works Aethos 6,22kg
Thanks for this. I'll give it a go.
I've heard these things cause the BB to creak. I'll have a go as they're not particularly expensive. Any tips on fitting the adaptors… grease etc?
Cheers
Cheers
Possibly, but don't worry, our stock OSBB/BB30s creak anyway..
More seriously, you can mitigate this largely by using this technique: https://www.youtube.com/watch?v=ow-iRD_dHs8
Got my frame yesterday. The shims did not come with the frame.
Here's some weights for those interested:
Specialized S-Works Tarmac SL6 Disc Frame 2019 Chameleon/Cyan Blue - 54cm: 860g (with hanger and cage bolts)
Specialized S-Works Tarmac SL6 Disc Forks: 388g (uncut)
Specialized S-Works Tarmac SL6 Seatpost: 175g
Specialized S-Works Tarmac SL6 CeramicSpeed Bearings: 48g
Wheels Manufacturing BB30 to 24mm Crank Shims: 48g
Specialized S-Works Tarmac SL6 Headset with all spacers: 70g
Thru Axles x2: 68g
Thanks for the detailed figures! 860g for a 54 inkl. hangers and bolts is really impressive, especially considering the supposedly heavy paintscheme.tnkn wrote: ↑Tue Nov 20, 2018 11:17 amGot my frame yesterday. The shims did not come with the frame.
Thru Axles x2: 68g
Any details on your planned build and expected final weight?
My spreadsheet is coming in at 6.5kg without cages, pedals Garmin mounts etc. With my super heavy Vector 3 pedals and the rest of the bits, I might just hit 6.8kg.
I've got for an Ultegra di2 groupset but using a Dura Ace R9100 cassette, chainset and KMC SL chain.
With a few choice upgrades, I should be able to get it down a couple of hundred grams.
I'm thinking of the exact same frame and size. Along with vector 3 pedals too. Thanks for the weights! very detailed listing.
tnkn wrote: ↑Tue Nov 20, 2018 5:33 pmMy spreadsheet is coming in at 6.5kg without cages, pedals Garmin mounts etc. With my super heavy Vector 3 pedals and the rest of the bits, I might just hit 6.8kg.
No problem. Once I get my wheels built I can start building up the bike. Will post the rest of the component weights and photos once done.
moyboy wrote: ↑Fri Nov 23, 2018 12:45 amI'm thinking of the exact same frame and size. Along with vector 3 pedals too. Thanks for the weights! very detailed listing.![]()
Specialized uses Syntace/X-12 (1mm thread pitch, conical head.)
No idea on the exact width for front and rear, for example my Trek is currently using something like a 123mm front and 168mm rear from Shift-Up.
TobinHatesYou wrote: ↑Wed Dec 05, 2018 11:11 am
Thanks Tobin... if it is the Syntace/X-12 with 1mm pitch and conical head.. then its what i needed..
Width is fine... thanks again.
