2018 S-Works Tarmac Disc
TonyM
by TonyM
Global wrote:
Wife and my Bike’s are finished here are photos. Mine total 6.36 kg or 14.02 lbs hers 6.36 or 14.12 lbs. All weights are with pedals and cages or cage on hers.
?? 6.36kg both (and 14.02 lbs compared to 14.12 lbs)?
Calnago
by Calnago
You know, I actually liked the style of the old Tarmac. But this new one... I just can’t even begin to like it. To me it looks some guy had two old school rigid mountain bikes sitting around, his own, and his 6 y/o kid’s. The kids bike had a broken front end and his had a broken rear end, so he took ‘em both down to the local welder and said “cut ‘em up and put the kids rear end on mine, paint it and call it good”.
TobinHatesYou
by TobinHatesYou
TonyM wrote:
Mon Jun 04, 2018 4:27 am
The numbers are fishy to me considering what I know of the Tarmac Disc frameset weights and what it took for me to get my Emonda Disc down to 6.65kg. Those bars, stems, saddles are all heavier as well.
tonytourist
by tonytourist
It's like the picture I quoted by CrankAddictsRich, no way that bike is under 14 lbs.
tonytourist wrote:
Fri Jun 01, 2018 3:43 am
CrankAddictsRich wrote:
Fri May 25, 2018 9:40 pm
My local shop just built up a custom SL6 disc for a customer that wanted it completely bare carbon. They took off all of the graphics... Red Etap, with Enve parts, etc. I think the only stock remaining parts are seatpost and crank. 13.3 pounds.
https://www.instagram.com/p/BjNajq-hed8 ... m.vreeland
What components were missing from this picture? :noidea:
I guess everything is lighter in NJ :lol: :smartass:
My friend had his Tarmac built up by Fairwheel and it was 15 even Picture Here. I haven't bothered weighing mine but I wouldn't be surprised if it were 7kg. Maybe someone from this thread can send me theirs so I can claim mine is low 14s :mrgreen:
cnyn
by cnyn
Can anyonone pls help me with the (annoying) bottom bracket question. Which diameters and width has the Tarmac Disc SL6?
I have a Quarq Red Dzero GXP and I am planning to install this into a SL6 Disc frame.
Do I need this BB:
https://www.c-bear.com/en/products/bott ... 1-sram-gxp
Diameter 46 mm, width 61 mm - OSBB "standard"
Or do I need this BB:
https://www.c-bear.com/en/products/bott ... 0-sram-gxp
Diameter 46 mm, width 46 mm - PF30
There are a lot of confusing articles and also some posts which tell some different things so I pls need your help.
Thank you
jhalmar
by jhalmar
^ S-Works SL6 bottom bracket is a normal BB30 bottom bracket so you need a converter BB30 -> GXP.
jlok
by jlok
You may want this as the bearings are native GxP 22mm that doesn't require the stepdown shim.
https://wheelsmfg.com/bottom-brackets/b ... black.html
idinfo68
by idinfo68
You need this model :
https://www.c-bear.com/nl/products/bott ... 0-sram-gxp
BB30 is PressFit 42 mm (PF42)...
It's PF42-68/73-GXP
rob01792
by rob01792
another question regarding the saddle clamp that comes with the frameset is it sutiable for carbon rail romin saddle cheers
CrankAddictsRich
by CrankAddictsRich
^^^ Typically, S-Works models come with two clamps that are suitable for both round rails and carbon 7x9 rails.
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
sychen
by sychen
Yes I have both with my bike.. If you don't have the other... Ask your shop. Would/should of been in the box.
idinfo68
by idinfo68
Mon Jun 04, 2018 1:49 pm
+1...
Global
by Global
Weights on my bikes are actual according to my scale and that of my local bike shop. Pm me if your in the area and we will find a scale. Thanks
Global :)
Global
by Global
Hers can go lighter when I change tires to Hutchinson 11 storm tlr 25s 225 grams actual on my scale vs zipp tangent tubeless 25s 285 actual on my scale with 30 grams of sealant each
Global :)
Global
by Global
Photos
Global :)
