2018 S-Works Tarmac Disc
fritzbox
by fritzbox
:thumbup: Top
riochang
by riochang
Just finished building a sagan SL6 disc.
Can anyone confirm if sagan edition paint weights substantially more? my size 54 bare frame (with only rear hanger) comes in at 960g!! that's almost 200g heavier than what most people quoted here.
mvcap
by mvcap
Great looking bike! What's the total weight as is?
Visus
by Visus
Yep the glitter paint is very heavy, I guess the paintjob weighs about 250-300g
riochang
by riochang
mvcap wrote:
Sat Sep 28, 2019 5:26 pm
Total weight without pedals is 6.8kg at the moment:
full sram red hrd groupset with extralite chainrings
new schwalbe pro one tubeless (approx 250~260g per tire)
riochang
by riochang
Visus wrote:
Sat Sep 28, 2019 5:30 pm
I was even questioning mysel that the frame is a fact 10r pro level frame with repainted s-work logo :shock:
scapewalker
by scapewalker
It's a great looking frame but 250-300g is outrageous.
That's literally the difference between the tarmac and a venge frame like wth.
cnynrpr
by cnynrpr
i guess if you have a UCI weight minimum, a little bit of extra weight from paint is the same compared to adding extra weight on a less blingy paint job. Not to mention better for marketing!
Stendhal
by Stendhal
riochang wrote:
Sat Sep 28, 2019 5:24 pm
I compiled a list of frame and bike weights from posts in the rim brake version thread (I posted the data in another thread if you’re interested), and yes I found that the Sagan colorway tended to be heavier. Small data set, but as I recall one poster’s Sagan stood out as a heavier outlier.
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
riochang
by riochang
Stendhal wrote:
Sun Sep 29, 2019 6:13 pm
Thanks Stendhal! this is really helpful, here's the link to his post if anyone's interested viewtopic.php?f=3&t=154296&p=1443272#p1443272
vertex19
by vertex19
heado wrote:
Tue Jan 15, 2019 4:40 pm
Hey boys,
first post here,
after months reading your publications i recently pulled the trigger.
Mine will be :
Frame: Sworks tarmac 58 (satin black / black reflective)
Stem: standard Sworks stem
Seatpost: standard seatpost
bar: Aerofly II : 44 cm
saddle: sworks power arc elaston
Groupset: sram Red etap 11v hydro wifli
Crankset: Quarq dzero red - 52/36
casette: red 11/32
Wheels: CL50 (clx were out of budget) fitted with turbo cotton
Bottlecage: Tacx Ciro black matt
pedal : probably dura ace .. still not decided between dura ace and ultegra.
I do not mention pieces like k-edge gps holder or bandit kit with co2 ..
I guess i did not forget anything, and hope it will be around 7.5 kg.
i'll keep you updated, thanks for all your inspiration !
(now getting back eating pasta ramen and potatoes ... too expensive :D)
Hi, did you measuer weight of frameset? Not glossy decal.. lighter than glossy??
bruno2000
by bruno2000
My frame was 945gr in size large. So yes it's heavier.
I guess the sparkles are real diamonds...
Campervan
by Campervan
Got the girlfriend a Tarmac disc comp di2 (2020) the other week, she has had 2 rides out on it, is happy with the 7.5kg's with pedals bearing in mind it's a 44cm. The 2 rides shes had, neither on the stock wheels, has borrowed my hunt 30's (Tubeless) and now my Roval CLX64's.
Now to start the search for some light semi aero wheels for her.
BMC Granfondo 02 105
Scott Scale 940
Boardman CXR 9.4 cxr CX/gravel mongrel
Btwin 540
Specialized Venge Pro Disc
vertex19
by vertex19
Hey boys,
first post here,
Mine will be :
casette: red 11/32
Hi, did you know weight of frameset?
ryanw
by ryanw
vertex19 wrote:
Tue Dec 10, 2019 12:31 pm
Hey boys,
first post here,
Mine will be :
casette: red 11/32
839g - 56cm
992g - 61cm
So somewhere in the middle...
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
