Rotor Uno Cassette shift and noise performance
tabl10s
by tabl10s
azriaziz wrote:
Wed Feb 21, 2018 8:00 am
I was on a full rotor uno including the cassette.
Swapped to a full di2 groupset.
What happened?
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8(build in-process).
TobinHatesYou
by TobinHatesYou
tabl10s wrote:
Wed Feb 21, 2018 8:20 am
What happened?
I played with Uno at NAHBS two years ago. It was bad. Shifting the front derailleur took way too much hand effort. There's nothing to it...Uno is priced higher than any mechanical groupset, and it's inferior to the electronic groupsets available today.
AZR3
by AZR3
Seems like Rotor is late to the party with the Uno. Perhaps if it had come out before Di2 it would have been more popular but I just can’t see how it competes with electronic groups or who would spend the money on it?
Edit-although that cassette is pretty sweet, I’m super tempted to snag one when my SRAM XG needs replacing.
Kaboom
by Kaboom
AZR3 wrote:
Wed Feb 21, 2018 1:42 pm
the cassette is incredibly sweet indeed, but at 350€ a pop its really hard to justify. There are plenty of other places to save 30g for a LOT less dough. I guess if you've scrounged every other gram possible it's worth it, but otherwise...
Then again if your cassette needs replacing anyway it's only 100€ more than DA or Red... but again, 5€/g is at the steep end of things, particularly if shifting quality is at stake as it has been suggested on this thread...
Imaking20
by Imaking20
I'm happy to take one of these off someone's hands if they're unhappy with the cassette!
Current:
Wilier Wonka | Specialissima
Retired:
Evo | T2 | Blue | Project C6.0 | Felt AR FRD | Colnago C59 NERO | 2014 S-Works Tarmac | S-Works Venge | Wilier Cento Uno SL | Tarmac SL2
TobinHatesYou
by TobinHatesYou
Kaboom wrote:
Wed Feb 21, 2018 8:50 pm
It won’t last as long as a SRAM XG1190 cassette either since the 25t second cog is also aluminum.
bm0p700f
by bm0p700f
that cog would last ages for me.
TobinHatesYou
by TobinHatesYou
bm0p700f wrote:
Wed Feb 21, 2018 11:38 pm
Just saying a weight weenie cassette might actually be used for climbing where the gram savings matter most.
tabl10s
by tabl10s
I have no hills where I live(not seeking any either). I just wanted one after I saw a Cycling Weekly "Gear of the Month" episode. Second will be here in a couple of days.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
MrAnderson
by MrAnderson
Sold my rotor uno cassette, it's way too noisey and the jump between gears didnt help either.
Back to Red cassettes now!
Imaking20
by Imaking20
My experience suggests these cassettes won't make it up a hill anyway! At least mine didn't...
Current:
Retired:
tabl10s
by tabl10s
Imaking20 wrote:
Thu Oct 04, 2018 8:08 pm
They must be adequate as Ollie Woodbridge at GCN used one on his hill climb attempt this month.
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
majorhunadadun
by majorhunadadun
TD1198s wrote:
Mon Feb 19, 2018 1:14 pm
I just picked one up. Shifting is spot on with Dura Ace 9150 Di2 and a YBN chain. The noise is about the same. Easy to install obviously being one piece. I'll report back if it eats through my Mig 150 cassette body as it is machined on the splines to further save weight.
Hey there! I'm eyeing one of these cassettes for a DA 9150 gruppo. How's yours functioning at this point??
F45
by F45
marcelflash wrote:
Mon Feb 19, 2018 7:59 pm
I noticed that it is also 10 speed body compatible
Well that's neat. I could put the 11-32 on my mountain bike.
F45
by F45
sooooo what happened?
