Want new disc aero <15lbs road bike... confused
by Nefarious86
Whats the lightest ViAS disc gettong about? A 58 is meant to be 7.4 stock... Its damn tempting with a second set of light shallow tubs..
Using Tapatalk
spartan
by spartan
SuperDave can you give us more info on the 3T Discus C60LTD. real weight/stiffness/durability.
tour magazine recently tested all the new generation aero disc wheels and 3T did very well.
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
SuperDave
by SuperDave
jlok wrote:@SD
How wide is the GravelKing 26mm when mounted?
26.8mm at 75psi
SuperDave
by SuperDave
spartan wrote:SuperDave can you give us more info on the 3T Discus C60LTD. real weight/stiffness/durability.
Sure, watch this space. I'll grab a video of me weighing them on a scale.
They can be set up with with the front 9mm QR, 12mm TA or 15mm TA and the rear is 10mm QR x 135 OLD, 12mm x 135mm OLD or 12 x 142mm. Centerlock only.
The stiffness I can tell you is incredible. The only similar road wheel I've ridden is the C75 Dura-Ace wheels. With 24 spokes 2x these have incredible lateral stiffness. I've got 2 seasons of 'cross racing on a set and have used them on my STRADA since June. I will say that they are not ideal for lighter riders in gusty crosswinds. I'm nearly 200# so I don't mind them for every day use but on a small frame with a small rider you'll feel them in 20+mph gusts. On the other hand, you'll have a big aero advantage so there's a trade off as always.
-Dave
RyanH
by RyanH
I need to make it down to Como to check out this thing in person.
TobinHatesYou
by TobinHatesYou
Nefarious86 wrote:Whats the lightest ViAS disc gettong about? A 58 is meant to be 7.4 stock... Its damn tempting with a second set of light shallow tubs..
7.4kg stock is a marketing pipedream. The various Venge ViAS Discs that have been raced in the World Tour have been 7.9-8.1kg with pedals and tubs.
maxxevv
by maxxevv
Giant Propel Disc 2018 ??
spartan
by spartan
https://cyclingtips.com/2017/08/giant-p ... ils-price/
real weights without pedals. with lighter wheels/crankset 7kg is possible. not bad for an aero disc bike that is stiff/compliant.
Current Rides:
L3X
by L3X
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=147781
The frame is already little over 1.5kg (ok this version has a ton of paint and includes bb..), fork is not the lightest, stem is heavy etc. Also if you for instance search for Kittels Vias Disc, which happens to be a size 58, they're all pretty heavy as well. Normally Specialized bikes are one a 3 year cycle and the vias was first released in 2015; so a new version in 2018 is surely possible. Also the latest new bikes all dropped quite some weight (Epic HT/Epic FS/Tarmac/Roubaix), so hopefully this will follow the same trend.
Marketing in cycling is total nonsense most of the time. When it comes to weight just don't believe anything until you see the bike / a part on a scale. 99.9% of all products go over the specified weight.
TobinHatesYou
by TobinHatesYou
L3X wrote:Also the latest new bikes all dropped quite some weight (Epic HT/Epic FS/Tarmac/Roubaix), so hopefully this will follow the same trend.
Tarmac frames with normal paintjobs are coming in between 860-920g. Not even that light.
L3X
by L3X
Agree, but dropping weight off the Vias really shouldnt be that hard to begin with :)
TonyM
by TonyM
2018 Scott Foil Premium Disc HMX DA 9170 Zipp 303: claimed 7.25kg, 16 lbs
https://www.scott-sports.com/us/en/prod ... =265330019
L3X
by L3X
Apart from the cables I actually think that's a really nice bike.
And I just reconfirmed I'm way too OCD as I noticed the Continental logos are misaligned between the two tires :smartass:
TonyM
by TonyM
Another good looking aero bike w/o cables is the:
2018 Ridley Noah SL Aero+ (not on their website but in their price list):
Frame weight is claimed as XXS 970g / XS 1,010g / S 1,030g / M 1,060g / L 1,090g.
Availability stated in the reviews is set for "beginning of 2018"....(I am waiting for an more precise answer from Ridley)
hannawald
by hannawald
TonyM wrote:Another good looking aero bike w/o cables is the:
Ridley Noah is pretty heavy, they claim the weight without paint and the fork is another piece of brick, they should do something with it.
other than that it seems pretty good, you can have custom paint, they have taller head tube, for me better as i would not need many spacers under the stem..
