Chainrings
glepore
by glepore
Need a set of 50-34 in 110 bcd. Will be run on Quarq/Sram crankset. 10 spd. Are Praxis forged rings worth the premium over FSA Pro machined or Sram rings? Any other recommendations?
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
morganb
by morganb
Are you running a SRAM drivetrain? If you are I'd do SRAM rings, if anything else Praxis, I've had subpar performance with pretty much every set of FSA rings that I've run.
audiojan
by audiojan
Yes, Praxis are definitely worth the extra money. Shifts much better and you'll notice the stiffness difference.
pdlpsher1
by pdlpsher1
pdlpsher1
by pdlpsher1
Stiffness comes from more materials used. Heavier chainring = stiffer chainring. Forging doesn't make Praxis stiffer.
A while back someone had said the Praxis is crap compared to Sram chainrings.
RyanH
by RyanH
With SRAM Red, I found the shifting to be better with Yaw rings than Praxis. Praxis is alright, but the old Force 10s rings shift just as well as my Buzz rings and weigh less (121 vs 131g).
@glepore, I sent you a pm, check your inbox.
Strava
DJT21
by DJT21
RyanH wrote:With SRAM Red, I found the shifting to be better with Yaw rings than Praxis. Praxis is alright, but the old Force 10s rings shift just as well as my Buzz rings and weigh less (121 vs 131g).
I'd avoid the old Force/Rival style 10 speed chainrings; they shift ok on a 130BCD, but I don't rate them on a 110BCD.
kfreytag
by kfreytag
Perhaps a useless addition given that I ride Shimano, but the Praxis rings on my ROTOR 3D+ shift as well as a Dura Ace 9000 crankset. I'm running Praxis rings on two bikes and wouldn't hesitate to buy again. Quality and function are top notch.
Life's too short to ride clinchers.
Current:
Parlee Z-Zero ISP
Santa Cruz Stigmata CC
Past:
Ridley X-Fire Disc
sungod
by sungod
i prefer praxis to sram red chainrings, shifting is fine (used them on mechanical red and on etap), i found the red rings wear relatively fast
the benefit of cold forged vs. machined rings is that the forging process changes the structure of the metal, forged parts are tougher - i think only praxis and shimano cold forge chainrings, the finish of the teeth is also noticeably better than my sram red rings
glepore
by glepore
Ryan was kind enough to send on a pair of 50/34 sram rings. Over a brief 50 mile test, I noticed no difference between them and the praxis 52/36 they replaced. Given that in 30 years of cycling I've never worn out a set of chainrings, suspect I'm ok.
Hexsense
by Hexsense
i prefer Wickwerks chainring.
Shift best in the bunch, better than Shimano (have Praxis, Red and Wickwerks, used to own Shimano 6800 crankset).
Their 53/34 ratio look boss too (i don't own that combo)
https://wickwerks.com/products/road-bik ... ide-53-34/
alastairb
by alastairb
Praxis way better than FSA; much stiffer resulting in greatly improved shifting.
Sent from my SM-G935F using Tapatalk
