Sram Etap
Jowwy
by Jowwy
I currently have sram etap set-up on my road bike in the current configuration
46/34 sram red crankset
11/40 sunrace cassette
wolftooth roadlink
i'm wondering if anybody else has sram etap on their bikes using anything other than sram red cranks. i'm looking at praxis or the new SLK touring crank in 46/30 configurations, which means i can remove the wollftooth roadlink and fit a much lighter 32t casssette
Thanks
raven14
by raven14
I have used Rotor Inpower 3D+ crankset and Praxis chainrings with Etap, works a charm. I swapped to Red Quarq D-Zero though, as I wanted total power to be measured and not just one sided. It looks better too :), but quality of shifting is the same and I can't notice any difference in drivetrain noises.
I also use DA9000 cassettes with Etap, no problem whatsoever.
Jowwy
by Jowwy
raven14 wrote:I have used Rotor Inpower 3D+ crankset and Praxis chainrings with Etap, works a charm. I swapped to Red Quarq D-Zero though, as I wanted total power to be measured and not just one sided. It looks better too :), but quality of shifting is the same and I can't notice any difference in drivetrain noises.
cheers raven for the quick response - guess i'm off to order some praxis cranks and the m30 BB and tool then
mdeth1313
by mdeth1313
I'm using clavicula cranks with praxis buzz rings and shifting has been perfect with 52/36 and 50/34 rings.
Speedplay is the devil!
jih
by jih
Using rotor and praxis. Front shifting is quite fussy to set up to be honest but works.
alcatraz
by alcatraz
Going from 34t to 30t chainring won't keep you the 40t gear ratio on a 32t cassette. You are still missing around 10% so closer to getting a 36t by comparison.
I am also very interested in those adventure cranks. Specifically the 48/32 and then swapping the 32t ring for a 30t. Perfect.
/a
Jowwy
by Jowwy
alcatraz wrote:Going from 34t to 30t chainring won't keep you the 40t gear ratio on a 32t cassette. You are still missing around 10% so closer to getting a 36t by comparison.
/a
I only needed the 40t rear in the alps - there's no climb I can't do here in South Wales on the 32/32.
I've done them all in a 34/32 but just want a little less stress on the legs
alcatraz
by alcatraz
One thing is "can" do and another to keep good cadence doing it. I think we can almost all agree we lower our cadence when climbing.
I might be wrong though..
/a
Jowwy
by Jowwy
alcatraz wrote:One thing is "can" do and another to keep good cadence doing it. I think we can almost all agree we lower our cadence when climbing.
/a
with the size on the b screw on the etap i could still fit a 36t sunrace cassette, which would still mean not needing the wolftooth and dropping weight over the 40t
therefore giving me 32/36.....but i'm pretty sure it wont be needed
