Rim brake thru-axle frames/bikes ?
ooo
by ooo
Anyone seen road or mtb frames/bikes with 142x12 rear dropouts (or QR/Thru-axle replaceble dropouts) and rim brake mounts (or both rim+disc mounts)?
FIJIGabe
by FIJIGabe
No, and I don't think you're not going to, because the axle that would work on the bike is only 130mm, rather than 135 or 142.
bremerradkurier
by bremerradkurier
Could be somewhat useful for an urban singlespeed bike, especially with a security keyed socket for the axles and super wide flange spacing for a strong rear wheel.
FIJIGabe
by FIJIGabe
I think we'll eventually see wider rear spacing (be it 142 for rim brake or 148 Boost for disc), but that would be for purposes of more gears in the back.
kavitator
by kavitator
Specialized SL6????? :roll:
bm0p700f
by bm0p700f
148x12 makes alot of sense for road bikes. Same with boost for the front.
wingguy
by wingguy
kavitator wrote:Specialized SL6????? :roll:
Umm, no? :roll:
The Wilier Cento10NDR has both direct mount rim and flat mount disc brakes on each frame and swappable dropouts for QR and Thru-axles. Probably some steel or Ti builders would make one for you as well.
But as stated how will you get rim brake hubs to fit thru axle spacing? Or would you lace a rim brake rim to a disk hub? :noidea:
wingguy
by wingguy
bm0p700f wrote:148x12 makes alot of sense for road bikes.
You think? I think componentry makers would be reluctant to increase Q-factor on road cranks and without doing that most chainsets don't have the space to shift the chainrings 3mm outboard without the crankarm ripping the front mech off.
deano87
by deano87
please check your PM's!
The Journey is more important than the Destination!
bm0p700f
by bm0p700f
i am happy to loose the FD.
ooo
by ooo
Found CX carbon frameset from china with convertable 142x12 / QR dropouts, rim brakes and 42c clearance:
Miracle CX536
https://www.instagram.com/p/BZOKCkuljTo/
http://www.miraclebikes.com/Product/detail/id/29.html
ghisallo2003
by ghisallo2003
I think this is actually a pretty good idea. I have built 1 x disc bikes for friends and the only technology that interests me in adopting is the through axle. I don't buy into either 1x or disc, but do like the solidity of a revised axle design.
TobinHatesYou
by TobinHatesYou
Other than weird options like the Wilier, I don't see this happening. Manufacturers are all-in on disc-brakes, there's no reason to offer a half-step that very few people would actually buy into.
pushstart
by pushstart
bm0p700f wrote:148x12 makes alot of sense for road bikes. Same with boost for the front.
I dunno; my heels are almost touching my 415mm chain stays with 142x12 -- I don't think I could move them out at all without stretching the backend out or widening the q-factor (using mtb cranks).
I am sure it would make for better wheels, though.
