Veloflex / Open Tubular max internal rim width safety
possibleweenie
by possibleweenie
dj97223 wrote:
possibleweenie wrote:
dj97223 wrote:My clinchers are Veloflex 23 on Velocity A23 rims, and I've had zero issues.
Damn. OK, Cool. Do you mind if I ask for how long and things to watch out for?mWhen I see photos of the bead I sort of see that they are a bit rounded compared to the molded tyres. Also, how long have you used that combo and have you tried running their 25s as well?
EDIT: Forgot to also ask about tire pressure. Thanks!
Thanks,
I've had this combo for several years, but the last few years I've run tubulars most of the time. Pressure usually is 80/90 PSI. I weigh about 150. I've not tried the 25's.
Cool. Thanks for the info. Really appreciate it.
c60rider
by c60rider
c60rider wrote:I've just fitted Veloflex master 25mm on the new Mavic Open Pro rims which are a C19 rim (I read somewhere they measure 18.6mm internal). I have yet to complete the bike and ride on them so I'll be interested anyone else's feedback. They've come out really big compared with the C17 rims I've fitted them on (Bora Ultra) but I don't have an actual measurement just yet but when I get chance I'll have a look and compare.
If I udnerstand this right, you have fitted an already used pair of Veloflexes (used on your Bora Ultra) to your new Mavic Open Pros? Did they stretch as people say they do?
I think I'll be getting my new batch of Velox tape tomorrow. I'll take my wheels off, take the Pro Ones out and measure the actual inside width of my rim as well to compare.
These are brand new veloflex tyres as I binned the old bora ones as the the sidewalls were torn by the carbon rims
hmai18
by hmai18
hmai18 wrote:Master 25mm.
SL23 v2.
I weigh 135lb. I ran them at 50 front, 60 rear.
Wow. That's pretty low pressure. Considerably lower than suggested. Did you use latex or butyl inner tubes? I would have thought lower than 60psi, even for someone of your weight, could mean pinch flats.
Thanks,
Latex, but I also realized that I automatically typed the pressure I'm currently running in my 28mm Schwalbe Ones. For the Masters, I was probably closer to 55/65 or 60/70. No pinches on either setup.
possibleweenie
by possibleweenie
SL23 v2.
Thanks,
Cool. Thank you. I am running Pro Ones (Well, was, I just unmounted them) How do you find the Ones in 28? My 25s were about 29mm on my rims.
possibleweenie
by possibleweenie
I see. Yes, Veloflex actually advises against using their clinchers on carbon rims because some may be a bit sharp on them.
I just measured the inside diameter of my rims: 19.2mm
mpulsiv
by mpulsiv
