Bleed screws in Shimano hydraulic levers
raggi
by raggi
My LBS had the same problem with my Ultegra R8070 levers.. Are these screws just rubbish?
guxo
by guxo
Yes.
I had the problem with the left one.
Afterwards, very carefully, tried to unscrew the right one and... worn...
PaulH
by PaulH
guxo wrote:thank you again
Could you re-use the screw?
Yes I have reused the screws (they are better now)
guxo
by guxo
ok!
thank very much
guxo
by guxo
i did it!!!
Thank you very much!
The key was the size of torcx: 10
I will try a trick to avoid rubber slippage: brushing with talcum powder. ;-)
TonyMM
by TonyMM
What was the problem with the “rubber slippage”?
PaulH
by PaulH
TonyMM wrote:What was the problem with the “rubber slippage”?
Well done glad it helped
guxo
by guxo
Just to prevent some oil remaining under hoods
TonyM
by TonyM
guxo wrote:
Mon Dec 18, 2017 2:29 pm
Thanks for the info. I may do the same...
DDX
by DDX
Destoyed on of the bleed screws today of my r8070 shifters....
succeed removing the screw with a torx.
But now I need a replacement asap, any hints where to get one ?
TonyM
by TonyM
I ordered some from my LBS but I was told they are on back orders at Shimano. I know why!
I wish we could buy a similar one somewhere else.
PaulH
by PaulH
Got mine from sjs cycles
PaulH
by PaulH
PaulH
by PaulH
Don’t k ow if they still have any in stock though
DDX
by DDX
found sjs cycles on google, but shows : 'more stock due in 28/03/2018'
I just mailed some local shops, hope one of them can get a replacement faster...
