Bleed screws in Shimano hydraulic levers
sorry to bump this but WOW, what a load of garbage. I blew £3.1k on a Specialized Roubaix, 500miles/2months later the front lever is getting close to the bar. Yep the pads have worn (it's hilly here but £20/set, eeek) but the front lever was closer when I bought it so I figured I'd bleed it after a hairy moment on Mow Cop in the rain today. Follwed the usual procedue. 2mm allen key stripped it (2.5 was too big) so I'm stuck. Swapped from back to front which has made the front useable for now. Will order some spare caps then try the Torx key. Not impressed
yeah not impressed with this either... it's only a matter of time. I also take exception with purchasing the "professional" bleed kit that did NOT come with the stupid funnel.. Really Shimano ?
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
I have the funnel, the oil, can't get the damn bleed screw out. And it's mentioned on here it's plastic, mine is definitely metal. Kinda chocolate metal but still metal. Will be ordering a park tool allen key as well to see if that works rather than a crappy multitool one. It's definitely 2mm isn't it? Think the old versions were 2.5 but 2.5 keys are way too big
bashing a torx in worries me a little. When I used a hex key it just woudn't budge then stripped. How much force did you need to get the torx in then to get the screw out? Have ordered 3 screws from SJS. It's not reverse threaded or somthing daft is it?
I've used a Torx as well, and a small hammer to get it in there. Then it came out quite easily. No it's no reverse threaded.
Just with my hands. The material of the screw is very soft.Vtwindr wrote:bashing a torx in worries me a little. When I used a hex key it just woudn't budge then stripped. How much force did you need to get the torx in then to get the screw out? Have ordered 3 screws from SJS. It's not reverse threaded or somthing daft is it?
