Arione 00 - which glue to hold covering down?
ParisCarbon
by ParisCarbon
Wondering what the recommended glue would be to hold covering down on the underside of the saddle.. I have a stretch about an inch long where it tucks underneath where the adhesive has let go and its starting to curl.. Just wanna save it before it gets worse since the saddle is in mint condition..
Thanks!
antonioiglesius
by antonioiglesius
Use some sort of contact cement, i.e. apply on both surfaces, let dry, then stick together. Should be readily available in local hardware store.
PinaF8
by PinaF8
I would try to get a hold of this cement called "Barge Cement".
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
hlvd
by hlvd
I'm sure Fizik saddles have a two year warranty, is it older than that?
ParisCarbon
by ParisCarbon
hlvd wrote:I'm sure Fizik saddles have a two year warranty, is it older than that?
Yes it is... its very minor, just dont want it to get worse...
ParisCarbon
by ParisCarbon
antonioiglesius wrote:Use some sort of contact cement, i.e. apply on both surfaces, let dry, then stick together. Should be readily available in local hardware store.
I was thinking the same.... luckily there is some in the basement!
Thanks for the replys guys
billspreston
by billspreston
+1 for Barge cement. Used this to cover an MCFK saddle with kangaroo leather and it's held up great.
