Garmin Edge 1030 and Vector 3
ergott
by ergott
Ghost234 wrote:
nickf wrote:The only feature that might get me to sell my 1000 is the improved route planning feature. I'm on the road every month for work and always bring my bike. Some of the routes my 1000 creates haven't been ideal. I needs to see one in person and compare them side by side. I have the silicone case on my 1000 so the color is irrelevant, I'm sure the 1030 will have the same available.
Use strava if you are not familiar with the area. The route planning feature on their website uses more commonly used roads when you click in the general direction you want to go. I used to travel quite a bit for work, so I've had to make my fair share of routes on roads I knew next to nothing about.
Also, I think Strava heat map has more users contributing so more data.
Sent from my SM-G950U using Tapatalk
by Nefarious86
Would be awesome if they just gave in and went to an SPD-SL platform...
Using Tapatalk
lyrictenor1
by lyrictenor1
Nefarious86 wrote:Would be awesome if they just gave in and went to an SPD-SL platform...
You can get Vector 2 and buy Garmin's Ultegra pedal adapter kit.
ms6073
by ms6073
Wonder if Garmin will offer a similar adapter kit for the Vector 3?
TobinHatesYou
by TobinHatesYou
ms6073 wrote:Wonder if Garmin will offer a similar adapter kit for the Vector 3?
Not going to happen this time unfortunately. The Vector 3 pedal body has an integrated battery compartment. The old pedals were generic Exustars with all the electronics in the antenna pods and spindles.
havana
by havana
Don't really see the problem. Keo and SPD-SL are essentially the same IMHO.
Most "innovations" in cycling are solutions for non-existing problems.
TobinHatesYou
by TobinHatesYou
Haven't used SPD-SL myself, but people I trust who have switched say it's a lot easy to blindly clip-in than KeO.
Stueys
by Stueys
TobinHatesYou wrote:Haven't used SPD-SL myself, but people I trust who have switched say it's a lot easy to blindly clip-in than KeO.
I switch between the two on my bikes, no real difference in clip in IMHO. Where spd wins is the clips are wider so feel as if they give a more solid platform, they are also better to walk in and don't have the squeak issue that the keo non slip cleats have.
by Nefarious86
The squeak alone is enough I'd never go KeO
Using Tapatalk
bm0p700f
by bm0p700f
mne dont sqeak, My cat squeaks so thankyou you dont want my cat.
TobinHatesYou
by TobinHatesYou
My Vector 2s don't squeak at the cleat interface either, but the right pedal body or the cartridge developed play in a little over a year. Every time I hit the power phase with my right leg, it clicks at the 3 o'clock position.
spdntrxi
by spdntrxi
Mine V1 upgraded to V2... are faultless. I still want V3 since it weighs less :)
moyboy
by moyboy
Their images look very Computer generated. DC rainmaker has some actual pics on his unboxing.
Tillquist wrote:Another Vector 3 picture
idinfo68
by idinfo68
Availibility here at very low price !
I received mine today, impressive ...
https://www.jeremy-cycles-limoges.fr/garmin-edge-1030-xml-355_373-2169.html
2old4this
by 2old4this
Has anyone moved from 1000 to 1030, yet?
I can get an 1030 at an LBS for $420, though I am not sure it is justifiable...
