Help: Jagwire on Supersix
mcinco
by mcinco
I'm trying to install the rear brake cable using Jagwire Elite Link kit and I'm having problems fitting the liner through the top tube. The liner is just barely larger than the front port. The exiting hole in the rear is plenty large enough.
At this point, seems like I only have two options:
1) Run bare cable with out liner
2) Make front hole larger to fit liner through
Also, it appears cable stops are not required/offered on the front entry port....is this correct?
Thanks for the help on my first build.
nickf
by nickf
I run a bare cable through the TT. Once you get the length you need, you cut the liner just a few mm past the last link. The link fits inside the frames cablestop, no end needed just the link itself resting in it. I made the hole on the headtube cable stop a tad bigger with a micro file, just enough so the liner fits through it. The liner is only for the cable segment sections only, not a fully sealed lined system.
mcinco
by mcinco
Excellent! Thanks for the quick response. I'll give it a shot tonight.
glepore
by glepore
have a good neodymium magnet handy to help you fish the cable, otherwise you will tear your hair out.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
nickf
by nickf
I just remove the seatpost. Gives you easy access
Frankie - B
Administrator
by Frankie - B
done ;)
mcinco
by mcinco
No access here...
nickf wrote:I just remove the seatpost. Gives you easy access
nickf
by nickf
My mistake! Maybe that was on another bike i worked on. I'll have to check mine next time i go through it. I swear i remember being able to fish it though there. Mine is a 2015 evo hm. These cables last so damn long I forget how its done, which is a good thing.
mcinco
by mcinco
No worries. The cable fed right through and out the rear. I must have gotten lucky!
nickf wrote:My mistake! Maybe that was on another bike i worked on. I'll have to check mine next time i go through it. I swear i remember being able to fish it though there. Mine is a 2015 evo hm. These cables last so damn long I forget how its done, which is a good thing.
