bontrager xxx integrated bars- real weight
campagowlo
by campagowlo
Im thinking about getting these. Advertised weight is 240 grams which seems optimistic. I would need a 11cm x 42cm. Anyone actually weighed these?
It's for my madone restoration project. Whilst the bars wouldn't be period specific it would save me a stack of weight. The alternative would be a kalloy stem and then a carbon bar like a controltech or deda.
NiFTY
by NiFTY
I believe the weight is actually accurate. I have held and flexed them when the first came out and they were the flexiest set of bars i have ever manhandled. Caveat is that they were the first generation and I am sure that they have been revised since (it seemed like a well known problem) but I would want to try them in my hands before putting my cash down.
glepore
by glepore
viewtopic.php?f=3&t=144200&hilit=chinese+75+integrated
Granted, these aren't the "real" thing but I have most of a season and several thousand miles on mine and I really dig them. I'm only 130lbs, but they are plenty stiff for me.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
fa63
by fa63
I have a set on the way; I will let you know what the weight is when the package arrives.
campagowlo
by campagowlo
Thanks for all the responses. Be good to see what a real weight is like, 240 seems very low.
Geordiepaul
by Geordiepaul
I'm planning to get a set of these. I had read they were really stiff but it concerns be something saying they're really flexy! Were this testing on a bike or just in hand?
Fisherfreerider
by Fisherfreerider
NiFTY wrote:I believe the weight is actually accurate. I have held and flexed them when the first came out and they were the flexiest set of bars i have ever manhandled. Caveat is that they were the first generation and I am sure that they have been revised since (it seemed like a well known problem) but I would want to try them in my hands before putting my cash down.
I have some and they were flexy in hand but completely unnoticeable on the bike. Not sure what mine weighed and they are on the bike now, have been for about a year.
Roni1
by Roni1
AliExpress fake ones are 267g for 120x420
fa63
by fa63
110 x 440 came in at 263g, including the Garmin mount.
TobinHatesYou
by TobinHatesYou
Slight necro.
Just got the 110mm/420mm version on clearance direct from Trek for $300. Weight including bolts and plug on the Blendr mount is 251g
Alexandrumarian
by Alexandrumarian
These things are incredibly light, less than an Extralite stem with Schmolke TLO bars for example. Most other integrated come up as boat anchors averaging around 400 grams. I wish someone would make something both reasonably light (300-350) and solid.
C36
by C36
Alexandrumarian wrote:These things are incredibly light, less than an Extralite stem with Schmolke TLO bars for example. Most other integrated come up as boat anchors averaging around 400 grams. I wish someone would make something both reasonably light (300-350) and solid.
The few info on those xxx bars have been quite a lack of stiffness (and considering that even soft combos are not very often called "soft" I would think those are really soft).
Like you I think something in the 300-350g would be nice. The only option I see so far are the canyon ones, in short length like the one I look after that's 335g on top of my head (and keep the aero benefit).
fa63
by fa63
I have not noticed any abnormal flex in mine, meaning that as best as I can tell, they behave the same as heavier aluminum bars on my other bikes. I am a big guy (100 kg), but a pretty smooth rider and don't pull on the bars too hard.
glepore
by glepore
Yeah, I don't know where the flex comments are coming from in ordinary use. Mine are almost too stiff.
TobinHatesYou
by TobinHatesYou
I'm 135lbs and my 15s max sprint is like 850W. I don't think I'll be flexing these too much.
