Shimano Pro Vibe Di2 stem's computer mount option.
reknop
by reknop
Nefarious86 wrote:Id say its more likely that it would fatiuge/fail easier
Although it not looks like a really thin plate between the stem and face plate (picture 14/17)
http://www.bikeradar.com/road/news/arti ... bar-50304/
And it seems like more riders from Team Sky are racing the new set-up in La Vuelta (Froomey & Wout Poels): https://keyassets.timeincuk.net/inspire ... 025p-1.jpg
https://www.remo-knops.com/cycling/
Anders3404
by Anders3404
Has anybody tested if the K-edge sport Garmin fits? It seems thinner than the normal K-edge mount
salesguy
by salesguy
For what it's worth, I just mounted these bars today. I have a lupine betty with a narrow AL mount similar looking to the k-edge, and it fits fine next to the stem. I'm using the new vibe stem as well.
There isn't a ton more room for a wider mount, but the lupine works. It measures 8mm in width.
I have a k-edge race mount on the way, anyone know the width on that? Otherwise hopefully this new stem mount becomes available.
spartan
by spartan
salesguy please post a pic on the mount posted.
where can you buy lupine mount online ?
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
salesguy
by salesguy
Here is a shot
Yes, that's the mount. Very nicely made, but not terribly helpful for a garmin.
billrush
by billrush
MayhemSWE wrote:F3 FormMount should work. Got them on two of my own bikes, works fine.
https://www.f3cycling.com/formmount-and-accessories
I emailed back and forth with F3. He says their mount will work on the upper rear facing bolts. That places the mount above the bar. I ordered it and will let you know with photos.
update 0418. It did not fit. Not even close.
TonyM
by TonyM
I Definitely couldn‘t live with the standard Garmin mount on my Pro Vibe aero handlebar and I did not want to wait until Jan/Feb until Pro finally release the K-Edge/Pro mount for the Pro Vibe stem/ handlebar so that I decided to file a standard K-Edge Garmin mount until it will fit the Pro Vibe aero handlebar. I also use some tape between the handlebar and the Garmin mount.
It takes times but it works!
Now I can fully enjoy my cockpit.
And in Jan/ Feb I can replace it with the new Garmin mount.
reknop
by reknop
TonyM wrote:I Definitely couldn‘t live with the standard Garmin mount on my Pro Vibe aero handlebar and I did not want to wait until Jan/Feb until Pro finally release the K-Edge/Pro mount for the Pro Vibe stem/ handlebar so that I decided to file a standard K-Edge Garmin mount until it will fit the Pro Vibe aero handlebar. I also use some tape between the handlebar and the Garmin mount.
And you did do a paint job of the Vibe stem front plate and the K-Edge holder as well. No shiny parts anymore but a full black stealth look and feel. :)
TonyM
by TonyM
Yepp ! I never liked the K-Edge branding on their mounts anyway...
lord_brush
by lord_brush
Looking at getting another set of the Pro Vibe compact alloy bars and the new stem.
I believe the new bar and stem combo have routing for Di2, but I've yet to see pictures of how this is done. Do the cables exit the bars and route thru the stem or what? Where do they exit the stem??
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
Hexsense
by Hexsense
lord_brush wrote:Looking at getting another set of the Pro Vibe compact alloy bars and the new stem.
There is a hole behind the bar clamp. Cable feed through stem and get out near top cap then Enter the steerer tube through special headset expander which also hold battery inside steerer tube (optional).
older MTB version.
https://youtu.be/EnGAm46QpUk?t=4m1s
new Road Pro Vibe.
https://youtu.be/pHoSDEXR3B0?t=5m18s
Battery is now rest inside steerer tube and connected. But how should we run cable to the frame is another issue, port on top of the stem is big enough for two cables, recess slot on the headset expander too but there is no way to route from inside steerer tube to the frame (normally). Maybe some special custom headset would do the trick? Until then, it's one line connect from bar to the frame as usual (heat shrink with brake cable to hide it).
PS. frames with top tube cable entrance like Giant Propel would easily enjoy short exposed cable from stem to the port too if you drill a hole out from top cap.
PS2. i don't think we can do much better than that without help from frame designer, see Trek Madone's headtube design.
https://youtu.be/l1O36yr6RE8?t=1m52s
lord_brush
by lord_brush
older MTB version.
new Road Pro Vibe.
Thanks. So....if I'm running older Dura Ace without the bar end junction box, is the new Vibe set up pointless?
reknop
by reknop
Here is the official Pro Assembly Instruction. https://www.youtube.com/watch?v=pHoSDEXR3B0
Geordiepaul
by Geordiepaul
http://edge-mount.bike/ Are releasing a Pro Vibe mount in the new year.
