Shimano Pro Vibe Di2 stem's computer mount option.
Hexsense
by Hexsense
I'm looking for a new Stem. Really like the new Shimano Pro Vibe Di2 stem's aesthetic and -10 degree angle. However it doesn't seem to be compatible with any stem front cap or stem bolts computer mount which is required for my set-up (no clamping space on the bar).
Then i found this picture. However, i can't find the information on K-edge website. Anyone know what mount is this? Any alternative computer mount options for this stem?
last picture from this article.
http://www.cyclingnews.com/news/demare- ... -aero-bar/
Edit: clearer picture here http://www.bikeradar.com/us/road/news/a ... bar-50304/
by Nefarious86
Damn that looks clean
Using Tapatalk
MayhemSWE
by MayhemSWE
F3 FormMount should work. Got them on two of my own bikes, works fine.
https://www.f3cycling.com/formmount-and-accessories
Monkeyfudger
by Monkeyfudger
No chance of that F3 mount working due to the backwards facing stem bolts.
OP, that set up looks ace, must be a new product from K-Edge, you can see how it mounts at the bottom in another picture. Might have to send 'em an email to see when it'll be available.
Hexsense
by Hexsense
Sent an E-mail to K-Edge.
They said this version is exclusive for Team Sky. However they will release a solution for this bar and this stem "very soon".
by Nefarious86
Hexsense wrote:Sent an E-mail to K-Edge.
What happened to the whole publicly available equipment rule....
Using Tapatalk
Hexsense
by Hexsense
They allow manufacturers to beta test equipments on pro teams for sometime before they release to general public. The mass produced version can be a bit different from test version though.
I'd rather question that rule to Continental Pro limited tires more than this case. That one is clearly limited to pros even in the name of it.
reknop
by reknop
Monkeyfudger wrote:No chance of that F3 mount working due to the backwards facing stem bolts.
Yes, I needed to invest in some new longer PB Swiss Tools hex bit for my Stahlwille Torque wrench, but those backward facing stem bolts give it a really clean look.
- I've switched to the Pro Vibe stem from a Ritchey WCS 4-AXIS stem;
- Available in 1.25 steerer-tube-clamp for Canyon and Giant headsets/bikes;
- Available in a -17 degree option (not all brands offer this aggressive angle);
- Excellent price-point and the DI2 integration can be cool;
My complete review can be found here: https://www.remo-knops.com/6953/vibe-st ... -bikegear/
I've sent the K-Edge team also an e-mail and I'm certainly looking forward to their reply. Hopefully confirming that this computer mount will hit general availability soon.
https://www.remo-knops.com/cycling/
MayhemSWE
by MayhemSWE
Well here are some news about a K-Edge mount specifically for Pro Vibe components. Maybe not quite what you were looking for though, as it's simply a variation of the regular mount but with a narrower clamp in order to git the Pro Vibe stem and aero handlebar…
https://www.bikerumor.com/2017/08/31/eb ... ar-mounts/
reknop
by reknop
MayhemSWE wrote:Well here are some news about a K-Edge mount specifically for Pro Vibe components. Maybe not quite what you were looking for though, as it's simply a variation of the regular mount but with a narrower clamp in order to git the Pro Vibe stem and aero handlebar…
That's indeed not the Christiaan Knees setup we've seen at Le Tour 2017. That was way cleaner .... but let's see what news comes out of Eurobike
Hexsense
by Hexsense
Disappointing.
In the text: "The insides had to be sculpted to fit the non-round section that curves into the flat section"
so it must match the bar's curve?
That means it only fit a single Stem and Handle-bar combo together?
hope that is false. I really need to use the Pro Vibe Di2 stem with my Enve bar.
MayhemSWE
by MayhemSWE
reknop wrote:That's indeed not the Christiaan Knees setup we've seen at Le Tour 2017. That was way cleaner .... but let's see what news comes out of Eurobike
Seems unlikely that mount will be released at all now. If they were going to release it, there would be no reason at all for the mount in the BikeRumor article.
reknop
by reknop
Agree :) :(
I ride a lot with my hands near the stem on endurance rides. The business case to bring the Knees' setup to the market might not be strong enough (volumes vs costs). However if it would get out, I would buy it immediately. :)
Monkeyfudger
by Monkeyfudger
I've been wondering if they perhaps don't want to release that particulare mount due to the way it clamps into the stem and the possibility of someone not tightening their stem correctly because of it.
by Nefarious86
Id say its more likely that it would fatiuge/fail easier
Using Tapatalk
