Felt Z5 clicking...tearing hair out of my head
PMCRyan
by PMCRyan
hey friends,
running into a bit of a problem with clicking/popcorn sound coming from what seems to be my crank area. i've replaced bearings in my rear hub already once and the sound only comes when pedaling, not when I'm idling (or maybe I can't hear over the hubs on my carbon clinchers??)
just a heads up on what i'm running:
felt z5 with standard tiagra groupset..but added a 105 crankset and new shimano r540 pedals to try and notch out those as possible problems.
running 55c FSE wheels..bearings went after around 700 miles in the rear wheel, replaced those. attached link below for sound.
https://www.youtube.com/watch?v=q3YUSd6 ... e=youtu.be
SOS!!
apologies if this isn't the right area, thanks in advance for any help.
thanks,
ryan
MAsshole
by MAsshole
Could it be chain related?
Have you run the cranks while the bike is on a stand?
PMCRyan
by PMCRyan
Just threw it up on the stand; sound isn't as prevalent as it is when I'm on it riding. Haven't noticed any differences in terms of when I hear it and which gears I'm in.
AJS914
by AJS914
Check, clean, lube, tighten quick releases.
mvacolnago
by mvacolnago
Also check the valve stems, just by hand see if they wiggle in the rims. If so a piece of electrical tape will silence em
PMCRyan
by PMCRyan
AJS914 wrote:Check, clean, lube, tighten quick releases.
did this, went through the whole gambit
PMCRyan
by PMCRyan
mvacolnago wrote:Also check the valve stems, just by hand see if they wiggle in the rims. If so a piece of electrical tape will silence em
thought this could be part of the reason, but ruled this out. definitely one of those ones people forget about tho.
wondering if it's the BB30 bracket..hoping something like that isn't terribly expensive to fix if it is, altho I'm not handy enough to do it on my own so my LBS would be getting the work.
imunwired
by imunwired
Have you checked the pedals and the headset?
PMCRyan
by PMCRyan
imunwired wrote:Have you checked the pedals and the headset?
pedals should be ok, just replaced those within the last day. headset i have not; sound is coming from rear of bike, still worth checking? anything i should be looking for in particular?
AJS914
by AJS914
Do you have the noise both seated and standing?
PMCRyan
by PMCRyan
AJS914 wrote:Do you have the noise both seated and standing?
tried getting off the saddle and cranking hard up a hill today to test it, didn't notice it any more prevalent than i did while seated on my saddle and pedaling. it definitely comes with pedaling though..idling doesn't seem to yield a sound
imunwired
by imunwired
I had a creak once. Thought it was my BB. Turned out it was the headset creaking when I pedaled under hard load. I slightly tug on the handlebars during those conditions. Carbon frames transmit sound pretty efficiently so in my case it took a while to pinpoint the sound issue. I just tightened the headset back down. Problem solved.
Also, not sure if I read whether you already looked at this or not and at the risk of pinpointing the obvious, have you pulled off your BB and reseated it?
Have you ridden in the rain recently?Sometimes after cycling in the rain, I have found that water can slosh around leaving residue in the BB and cause minor creaking.
PinaF8
by PinaF8
I once experienceD this creaking and it drove me nuts trying to find the source. my investigation led me to the front wheel preload bearing cap. Good luck!
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
taylorpetie
by taylorpetie
^^ and sometimes make sure the rear cassette lock ring is tight (torque to setting) and if u want to apply some light grease between the rear hub and rear cassette. It can be anything but I recently swapped wheels (and replaced the rear cassette) and started to have similar creaking until I did the two mentioned.
2lo8
by 2lo8
What about the good old shoe hitting front derailer cable end, which never shows up on the stand for obvious reasons.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
