SRAM Red Chainring confusion
TimW
by TimW
Hi all. Just got myself an etap HRD group set for new ride and a dzero red powermeter. I need some chainrings for this 110bcd 52/36.
I would like to stay with SRAM rings for now. I think I need x-glide r but want them in black as pictured on the SRAM site.
Problem is I can only find these as Red in the grey colour. The black version is listed as Force.
Two questions
1. Are the rings actually the same?
2. Is there a x-glide r inner ring?
There is some terrible SRAM availability in the UK right now for some reason.
Sent from my SM-G928F using Tapatalk
havana
by havana
Dzero HB version or NHB?
SRAM availability issues also exist in the rest of Europe. Mantel and Bike24 do have stock.
Most "innovations" in cycling are solutions for non-existing problems.
TimW
by TimW
Hb (which I think is the new standard?). The SRAM range is a bit a mess tbh.
TimW
by TimW
Ok downloaded the SRAM spares catalogue and went on part number for Glide-r.
commendatore
by commendatore
I've been in a similar boat trying to figure out what the latest revision is in black. I may just order praxis instead.
Spinnekop
by Spinnekop
Bought the Glide R set paired with Quarq Dzero spider.
The chainring is "dual use" type in the sense that if you run the Non-hidden bolt, it fits one way around and if you run the hidden bolt (like with the Dzero) then you just turn the rings 180 degrees to fit.
There are two pins on the ring to prevent chain suck
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
Spinnekop
by Spinnekop
worthy to note that if you run the hidden bolt setup, you will need a special chainring bolt for the hole behind the crank.
TimW
by TimW
Top tips. Yeah my DZero came with the HB bolt set.
Valbrona
by Valbrona
Spinnekop wrote:worthy to note that if you run the hidden bolt setup, you will need a special chainring bolt for the hole behind the crank.
SRAM hidden chainring bolt set: 11.6918.000.000. They call this set 'Quarq HB 5STL, Blk.
Vermu
by Vermu
edited (learning how to use search)
Y26
by Y26
I am looking at similar setup.
One needs the Buzz series chainring from Praxis.
Or Absoluteblack oval for sram.
pdlpsher1
by pdlpsher1
To save a bit of money I've been using Sram Red 10-speed chainrings on my 11-speed system with a Quarq crankset. The 10-speed version (50 tooth) costs about half of the 11-speed version and I find no difference between the two in functionality except a seven-grams difference (10-speed is a bit heavier). You can find 10-speed version made for a hidden bolt with the hidden bolt already installed and only one chain guard installed (as opposed to two chain guards on the 11-speed version).
