Suggestions for finishing bar tape ?
gtv18
by gtv18
Nick W.
Veni, Vidi, Velcro
(I came, I saw, I stuck around)
Wraping bars from the top to the bottom does not look right IMHO.
bremerradkurier
by bremerradkurier
color matching heat shrink tubing seems like it would be a good solution.
kode54
by kode54
MikeD wrote:3M makes one of the better electrical tapes. Avoid cheap Chinese tape.
+1
makes a big difference. the common ones found in hardware stores are junk and use terrible adhesives.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
PrimO
by PrimO
Gorilla tape...it will never come off and there is no need to stretch it either, just a few wraps and cut it so that the end is on the underside...job done.
kdawg
by kdawg
Definitely decent tape - the cheap stuff doesn't stick. And 2 wraps max - it's just to stop the end unrolling so you don't need to use the whole roll of tape.
It just goes on the tape - not stuck to the bars as well.
I'm left handed, if that matters.
wobbly
by wobbly
Thanks all !
3M it is :thumbup:
by Nefarious86
Wrap and cut the bar tape to suit, unwrap a turn or 2, start the electrical tape on the bar and wrap the bar tape over the elec tape and then 2-3 wraps to finish. Clean edge and solid anchor for the tape. Dab of super glue on the end of the tape stops fidgeting fingers lifting the finished edge.
Using Tapatalk
