Retrofitting etap in to Campy 10 speed shifters
uraqt
by uraqt
So I have a few bikes, all Campy 10 speed, and I am thinking about buying etap and fitting it to a campy 10 speed shifter. There are pix from the patent office of the etap shifters electronics. Anybody do something like this? I think you could also use a blipbox and some custom blips switches ...
Any other ideas?
C
motorapido
by motorapido
I would think that a custom momentary switch blip would work, i've done a few similar types of install, but to use Di2 on Sram HydroR rim and Disc brake lever bodies. Either by grafting on the whole lever and shifter electronics or by custom switches.
will have to re-host the photos so you can see the detail as they were on photobucket.
Looking at the Ergo Shifters, you could gut the mechanism and mount a small switch to the inside of the lever body, and then make up a piece with an actuator cam to fit onto the shift levers pivot shaft. Then run a cable and plug to the Tri blipbox.
