Ax Lightness Vial Evo Frame & Morpheus Crankset, rubbing at the BB
DEADRE
by DEADRE
Hi Everyone,
Recently finished building my Vial Evo R with the Morpheus crankset & took it out for a 20 mile spin.
After the ride, I took off the crankset and noticed on the non drive side, that the cranks were rubbing at the outer edges of the BB. I used a 1mm shim on the the drive side (no signs of rubbing) but not on the non drive side. I'm assuming in this case that I should had as well, right?
Prior to the above comment, I also I put a wavy washer on the non drive side, but the free spinning of the crankset was none existent, so I removed it.
If any of you guys out there have any suggestions or ran into the same predicament, please let me know how I can resolve this.
Thanks everyone!
