skunkworks #tidylight for exposure lights
sugarkane
by sugarkane
ey guys so I've been working on this project for a while now and finally have a dialled product and have found some one to print them in a resolution and material that makes them a product worth selling
they come in 2 styles. -12 and 16 with the 12 suiting any stems running from -6 to -10 degrees and the -6 mount for those badassed enough to rock a -17 stem.
they are compatible with the 23mm bodied exposure lights, basically the diablo and all the other lights in the range under it. Mount wise they'll work with most 4 bolt style mount e.g. the Fetha and kedge units ( any thing that runs a kedge style insert) and will work with the wahoo inserts using a different screw set and coming through from the bottom..
ohh an the 'white' mounts in the pictures are from the STL files or the last prototype test print i had done
let me know what y'all think..
for more of my custom stuff an builds check out
https://www.instagram.com/skunkworks_bikes/
ergott
by ergott
Looks great!
:beerchug:
sugarkane
by sugarkane
ergott wrote:Looks great!
:beerchug:
thanks dude really happy with the design and the printing
glam2deaf
by glam2deaf
So slick. It's a shame the SRM mount is too small to do anything like this.
ManekiNico
by ManekiNico
…aaaand I just bought Exposure’s mount for action camera brackets. :evil: Not the most weenie solution when you factor in the weight of the combo mount, thumb screw, and light mount. Except for not being able to adjust the angle, this seems like a much better solution.
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
sugarkane
by sugarkane
ManekiNico wrote:…aaaand I just bought Exposure’s mount for action camera brackets. :evil: Not the most weenie solution when you factor in the weight of the combo mount, thumb screw, and light mount. Except for not being able to adjust the angle, this seems like a much better solution.
Beginning work on the adjustable one tomorrow 8)
rpowell
by rpowell
cool! it looks like the white ones use an sls process but i cant tell what type of printer is making the black ones. how does the snap fit feel? have you cycled it to failure? im thinking of something like this for my mtb.
showdown
by showdown
Looks great... A great idea too... I did something almost identical a while back but instead of a fixed exposure mount I used a GoPro mount for versatility- I can use lights or cameras etc...
I'm guessing thats LSL (laser sintered nylon) right? I've been 3D printing a lot of bits for my bike and have found that to be the only material that has the right combination of strength, flexibility and resolution.
viewtopic.php?p=1267199#p1267199
kdawg
by kdawg
Would make me nervous having the open end facing down on a bumpy surface. Would a slot for a cable tie/Velcro make sense?
I'm left handed, if that matters.
ManekiNico
by ManekiNico
sugarkane wrote:Beginning work on the adjustable one tomorrow 8)
:thumbup: :thumbup: :thumbup:
sugarkane
by sugarkane
Sorry I've been ride This is weigt weeinies after all Image
kdawg wrote:Would make me nervous having the open end facing down on a bumpy surface. Would a slot for a cable tie/Velcro make sense?
Totally not nessaery they have been over engineered and this is the 6th revision of the printing type, company doing it and the models. They have a very firm hold and the light really snaps in. The 4th revision where I changed the print angle and thickened the band by 0.2mm you couldn't get the light into :thumbup:
showdown wrote:Looks great... A great idea too... I did something almost identical a while back but instead of a fixed exposure mount I used a GoPro mount for versatility- I can use lights or cameras etc...
I saw that nice work.
And yeah it's SLS
Broady
by Broady
Looks great, I'll probably pick one up for my K-Edge when available.
sugarkane
by sugarkane
Broady wrote:Looks great, I'll probably pick one up for my K-Edge when available.
Available now
rpowell
by rpowell
i was going to ask for the step file to print a ffew for you using RPU70 but shipping to Syd from California sounds prohibitive. There seems to be a big demand for these low volume mounts which makes 3d printing perfect.
sugarkane
by sugarkane
I'm getting them printed locally on a very expensive European machine. The quality of the prints is really good with a 0.1mm res. I've been through 5 printers so far including shape ways, who's SLS stuff compared to these guys work is rubbish. My printers are using very high quality media and a 50/50 fresh powder rate. A little costly but worth it
