Campy Chorus Brake Calipers Clearance
RyanH
by RyanH
@silvalis, I only had a little time with them back to back. Before they were on my Classic with different wheels so it wasn't comparable. I can't definitively say how they were different other than I immediately noticed a difference. Maybe Cal can pay better attention than I did. If I were to try to pin point it, I'd say that the new design has slightly more grab to it while the older design has more modulation at slow speed.
Strava
Calnago
by Calnago
Ok... I can report back here now and state that the Dual Pivot Chorus Calipers (both front and rear) do indeed provide slightly more clearance than either the Record or Super Record Calipers. What was a barely see daylight kind of "flint catching" situation with Record or Super Record calipers is now perfectly fine clearance at 2mm with Veloflex Vlanderen 27mm tubulars on new Campagnolo Boras with the Chorus calipers.
silvalis
by silvalis
Are there any other major differences between chorus and record/sr right now? Because the price jump is huge.
Chapter 2 Tere
Scott Spark 720plus
Calnago
by Calnago
In the brake calipers? There's differences, like ti bolts, a different type of barrel adjuster, a bit different method of micro adjustments and caliper centering. But functionally Chorus is very very good. If you're on a budget you shouldn't feel like you're missing the amount of price differential in performance.
silvalis
by silvalis
Yeah just the calipers. In the process of planning out a new build, not exactly on a budget, but just a bit begrudging when even the campy blurb barely differentiates between the models, yet a set of record dual pivots cost more than twice chorus.
Chapter 2 Tere
Scott Spark 720plus
vektor
by vektor
Sorry for the resurrection...
I'm having the same issue as described above on the rear, but with the SR single pivot brake caliper (see attached photo). Little movement causes the tyre to touch the caliper arms on the side at the top..
Is the Chorus solution also true for the single pivot brake? Was also thinking about adding additional tooth lock washers...
Thanks for any real life experience!Image
RyanH
by RyanH
You're going to want to get the dual pivots as they have more clearance. Single pivots are limited inherently by true design.
Strava
tommasini
by tommasini
vektor wrote:
Sun Apr 01, 2018 9:27 am
Look how high up the pads are - they look to be at the top of the slot. That suggests that the bigger problem in one that is inherrent (cant be changed) with the frame - that the brake bridge is rather low.
roadhog44
by roadhog44
Later Chorus calipers will definitely provide more clearance for you, I can see that the issue is the brake caliper and not frame brake bridge. I had a similar situation on my Helium SL...Chorus added another 2-3mm clearance over a S Record single pivot on the rear - And thats ALL ROUND the tyre too!
vektor
by vektor
Thank you for your very appreciated answers!
The frame's brake bridge provides enough space. I will give it a try with the dual pivot, that's currently mounted to the fork, as I could probably easily swap my single pivot to a dual one.
If that's not gonna work, I will check the new Chorus calipers.
BTW: I installed additional washers and that helped a little bit, as the brake is moving tangential, giving a little more space...see the attached photoImage
vektor
by vektor
Had the chance to try the dual pivot SR rear brake today...made it even worse. Brake was sitting on the tyre. Unfortunately no photo :/
I'm thinking of sticking to the current solution...works for 99% of the time...
Calnago
by Calnago
@vektor... not sure if you read the whole thread, or maybe it wasn't discussed explictly, but the single pivot Campy brakes have a high peak in the middle, so at the very center you're probably not going to do much better than that. Dual pivots have better all round clearance, and where the single pivots may crowd the side of a larger tire when activated, the dual pivots have more clearance that way. But as you widen the pad clearance for wider rims, the arms come down towards the top of the tire and with no tension on them they would sit right on the tire no doubt. They may sometimes be able to provide adequate clearance when adjusted for specifc rims, but depending on tire size, let's use Conti 4000s 25mm clincher as the goto example, not always. Chorus Dual Pivots would povide the most clearance all round of any of the Campy calipers at the moment, but I'm not sure about them being higher specifcally in the middle than your single pivots, but they are definitley higher thant either SR or Record. I started this thread and ended up getting some Chorus calipers to verify this, as the responses to my intial query were sometimes conflicting as to whehter there was more clearance or not. There is... maybe only a couple of millimeters, but that was enough for me.
But I think the more critical constraint that you have is as @tommassini above noted... your brake bridge is low enough that you have to have your brake shoes mounted very high in their slots. Unless your brake track is well beyond the standard spec for what brake tracks are supposed to be, there's really not much you can do about that. An extra serrated washer between the brake and the bridge may help a little bit, depending on the angle of the stays relative to the brake track, but probably not enough to make a useable difference in your case.
I'm not sure the Chorus calipers would give any more absolute clearance at the pique than your current single pivots. The Dual Pivots are however, much nicer when it comes to fine tuning and setting the adjustment. Good luck. I have a bike with single pivots on it. At some point, because I'm curious too now, I'll throw the dual pivot Chorus on there to see if it has more clearance than the single pivot does.
Good luck.
FELIPERSANTANA
by FELIPERSANTANA
thank you all for the reviews. I have a dogma 60.1 with a super record. and this group is currently in my Cervélo Rca. I tested this week the 28 mm gatorskin tires on the rear of the RCA and ok. the Super Record brakes offer good clereance. But in the lead I have a problem. I thought the potenza and chorus + 2015 brakes would solve my problem. Am I right?
RyanH
by RyanH
I managed to get just enough clearance on the Litespeed Classic by putting some washers on the inside of the brake shoe area. It was the ones that come with ee brakes so probably 1.5mm on each side. Prior to that, applying the brakes would cause the arms to touch. After they didn't touch.
Strava
