Integrated bar stem?.. that houses EPS interface module?
Tommo
by Tommo
I'm currently in the process of researching integrated bar/stems for a build I'm having done. One of my goals is to clean up the cockpit area inline with the current trend I.e Madone9 etc. I've just read a review on the new Willier cento 10 air and it's Alabarda bar/stem which does what I'm looking for. The trouble is it's €650. Are there any alternatives out there... I like options. Alternatively are there any stems that could offer this if I go down the separate route? And would it be possible to port the wiring directly into the frame if so?
Tommo
by Tommo
Come on team?... I've found a couple...
Vision metronome 5D and Syncros RR 1.0. The later looks the style most harmonious with the build but does anyone know if it will accommodate the EPS interface module? Is that the same size as a Di2 module?.. as that fits.
